Question about Garden
I have a scotts with a Briggs & stratton intek 121682-0122-E1 My problem is, I removed the valve cover (dont ask me why) and after I put a new gasket and replaced the cover the oil leaks from the valve cover I have taken it to a shop with no luck new gasket, silicone and the problem persist any advise?
  • georgecuevas Jun 01, 2010
    thank you for your reply, but; you advise has been done to no avail.. the amount of oil leaking is substantial. to the point that I have to refill the oil if I have the machine on for 20 minutes
  • 819 Answers
Remove the cover again. make sure both mating surfaces are completely free of old gasket material, dirt and debris. use a bit of fine sand paper to make sure its clean. use a new gasket. when you bolt the cover on, use a criss - cross pattern when tightening the bolts. go over them a couple of times. if you have been tightening in a circular pattern, the gasket can distort causing your leak. good luck!
Posted on Jun 01, 2010
  • Geoff Walton Jun 01, 2010
    is it possible that the cover was over torqued and cracked? clean the cover and look at it very closely, that would be my next suspicion.
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Oil coming from valve cover
did you gap spark plug to.028" ? may need to replace the valve cover gasket.
May 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
7 hp oh valve sears frame
Remove the cover for the valves by the spark plug and adjust both valves at .008 gap
That will end the back firing. They have locking nuts (double nuts) at each valve to adjust
Jun 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
246 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
