JUST MOVED IN THIS HOUSE AND THE DUET DRYER WON'T DRY CLOTHES ALL THE WAY THRU - KEEPS SHUTTING OFF., BLINKING SCREEN, DRYER LIGHT ON AND THEN JUST SHUTS DOWN COMPLETELY. CLOTHES ARE STILL VERY DAMP - IS IT A SENSOR OR OPERATOR PROBLEM? THESE APPLIANCES ARE VERY NEW
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes. As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time. If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent. There reasons why a dryer will not dry clothes: Clogged Lint Trap Crushed or clogged vent Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve. So check what I told you and this should fix the problem right away
is this a washer or dryer if its a dryer you need to check the air flow where the dryer vents outside the house make sure it is flowing good it may need to be cleaned out
so what was the problem or solution?
