Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice wll not dispense from the door, it will occassionally dispense but rarely. The ice bin is full, there seems to be a circuit problem. Is there a way to test the door circuit assy. to make sure that is the problem. I saw the cost of the panel display to be around 128.00.
  • 54 Answers
Before getting carried away check that the small wire bar above the ice is down and that the ice is not so old it has stuck together in one big block.
Posted on Jun 01, 2010
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Lg freezer ice maker making ice but not dispensing
I have the same problem. I am getting tired of having to clear it out about once a week. I take the ice holder out and empty it in a large bowl and remove any large, melted together pieces, then replace it. It works fine for a while.
Mar 17, 2017 | LG LSC23924ST Refrigeration : Refrigerator...
I have a GE Profile Artica. Dispenser is not dispensing ice even though ice bin is full. When i press the for ice to dispense , the light dims and the compressor stops.
Try taking out the ice bin press the door light switch and dispense ice button at the same time and see if the motor bracket turns without the ice bin in place. It is possible you have ice in the bottom of the bin that is frozen and jamming the movement of the auger. If not the problem may be a defective auger motor=> WR60X10259 Auger-Motor
I will be here should you have questions, Sea Breeze
Mar 01, 2013 | GE Refrigerators
Ice dispenser auger does not work.
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Feb 15, 2009 | GE Refrigerators
GSS23LSTA SS WILL NOT DISPENSE ICE OR WATER
Open freezer door, pull out the ice bin, push and hold the door switch, and push on the ice dispenser pad / lever. The U shaped auger drive should turn at the back of the freezer behind where the ice bin was. I suspect it is not turning. If this is the case, you have a frozen auger motor. Just thawing it out will not permanently solve the problem, it must be replaced and a " boot " installed over it. It is important to know the exact full model and serial number, as there are several motors to fit various models.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser in door clogged up or frozen
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Oct 15, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
