Question about LG WM-2277HW Front Load Washer
I get a prompt of "LE" when i try to start a load. do you know whats happening? Lost my manuals.
  • LG Master
  • 43,501 Answers
That is caused by too much or the wrong kind of soap...
LG Washing Machine LE Error Code or Fault Code
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Posted on Jun 01, 2010
Water will not load into machine, F 30 keeps flashing on panel
Hello there
The F30 code refers to a failure of the dispenser motor. The clicking that you may be hearing if so.. probably the dispenser motor switch going on and off trying to activate the dispenser motor.
Here is the service manual.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
I would recommend you contact Whirlpool and see if they will not give you warranty coverage since it was so close to the expiration. If not, I think this is an easy and relatively inexpensive repair that with the help of the manual you can do yourself.
Good luck and let us know what happens.
Best regards MIke
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LE sign comes on
over suddsing is what this erro indicates. Clean the pump out as well as the hoses and use less soap.
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG WM-2277HW Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG washing machine Model # wm2077cw
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Jan 11, 2009 | Washing Machines
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Web cam problem
Best to start from scratch, remove your driver if it's installed from Add/Remove programmes. Make sure your cam is dissconnected and try the driver from this site:- http://downloadfinder.intel.com/scripts-df-external/Product_Filter.aspx?ProductID=349&lang=eng Install driver and then connect camera when prompted. Although I don't know what you mean by "won't accept any file name"; make sure that you install correct driver for your operating system.
Dec 15, 2006 | Intel Easy PC Camera Webcam
LG WM-2277HW Front Load Washer Logo
140 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
