Question about Bosch 4100 10" Worksite Table Saw
Bad vibration and noise from saw
The saw makes a grinding sound and has a bad vibration. I have cleaned the saw thoroughly and checked the brushes. I have replaced the blade and still get the problem. It sounds like something is grinding inside the motor.
    Problem Solver:
  • 6 Answers
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Posted on Jul 25, 2010
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
When i turn it on the blade is binding an is making a grinding sound
I would suggest that the bearing has failed and the armature is poling out on the field shoes
another problem may be that the brushes are gone and the commutator bars are badly damaged
Sep 28, 2015 | Saws
I have 2 DW715 miter saws given to me, with the blades off one sounds wicked, you can spin it forward by hand but stops/locks up trying to spin in reverse. Sounds like a belt or bearing. The other one...
The first one sounds like an armature bearing - pretty easy fix if you have access to a press or even a bearing / gear puller. Make sure the saw is unplugged, remove the end cap on the motor and the 2 carbon brushes. remove the 4 screws holding the motor housing to the saw and pull it off. Then, pull the armature straight out - replace the bad bearing, and reverse process.
The second one sounds like it is missing the arbor bushing #152636-00 or it has a bad blade bolt #145344-01.
Nov 10, 2014 | Saws
Dewalt saw blade won't stop when I off the trigger. How to clean the communicator?
This problem can be caused by the brushes wearing out. Check brushes first. If you need to clean the commutator it is best to remove the armature completely and use a scouring pad similar to what you would wash your plates with. You can use wire wool, and if you do (it is quicker and a bit more thorough) make sure you clean between all the comm segments after with a stanley knife or something so there is nothing left to short across them.
The really professional way to sort the comm is to 'skim' it on a lathe, which would mean spinning it up on a lathe and smoothing it out with a hardened cutter. This also leaves the comm nice and flat, ready for new brushes, but should only be done by a competent person as it can go wrong quite easily. Also after skimming you should cut back the insulation slightly so there is a nice step between segments.
Jul 15, 2012 | Saws
Why is my tile saw making different noises?
Sounds like you have bearings going/gone bad. If it's a direct drive model, check the bearings in the motor and on the arbor. If it's a belt driven model check the bearings on either end of the arbor shaft. As bearings go bad, someone using the saw regularly will notice a different tone in the tool. If you are getting vibrations that bad, the bearings are already loosing balls or the race is tore up and all the balls are on one side and can't doing their job correctly.
Mar 10, 2012 | Ridgid Saws
Makita ga9020-230 making grinding noise and then starting flicking sparks even after replacing the brushes, please help
It sounds like the armature is shot. When the armature goes bad you will see excess sparking from the brushes.
Jul 04, 2011 | Makita GA9020 Angle Grinder
How to service homelite chainsaw
I take it you have a gas powered saw. Before starting any work on the machine, remove the plug lead.
To service it, remove the blade and guide and clean them all thoroughly. Clean the drive sprocket and its recess, this is best done with compressed air or at least a stiff paint brush. Inspect the chain cutting blades for damage and also the guide links and the groove they run in. Lubricate everything lightly with a thin oil before reassembly.
Check the spark plug, clean it thoroughly (not on a rotary wire brush) or replace it. Clean the air filter by blowing it with compressed air or a vacuum cleaner. If it is too soiled, replace it. Drain the fuel from the tank and check the fuel filter in the fuel tank and clean it if it appears to be dirty or contaminated. Blow the cylinder and the head cooling fins clean with compressed air, this can be done with a brush, but will require the cooling duct to be removed.
That is about all that can be done on a cursory service, anything further will require stripping the carb and removing the exhaust, neither really necessary unless a problem is being experienced. Everything is relatively simple to carry out and should not take too long. Please rate this response.
May 20, 2011 | Homelite Garden
Makita 9523NB angle grinder is suddenly suffering vibration and some emitted from motor before stopping. I have replaced brushes (original brushes were hardly worn) as 1 of the springs had little tension...
You say it spins freely but is it smooth. If not it could be one or both of the bearings the armature spins on. More likely than not you have one or more fan blades broke or missing. Not much weight by themselves but at the speed these things spin the more blades broke off, the worse the vibration. You have to romove the brushes, take off the gear housing and remove the armature to check both the bearings and fan.
Aug 03, 2010 | Makita Saws
Bosch 4100 10" Worksite Table Saw Logo
484 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
