Question about Sony VAIO PCG-K35 Notebook
Sony vaio notebook
Computer will not turn on. With or wihtout the battery inserted.
    Scholar:
  • 144 Answers
Take off the battery and try to plug ac-acapter.Notice that you have any light on the notebook incase you do have like power light.... then follow this step
it could be the motherboard problem but what I would like to test here first is remove some component one-by-one and try to turn your notebook on and see...(see mean any noise or light come up)
1.remove battery
2.remove harddrive
3.remove memory
4.if possible remove cdrom
5.anymore incase you have
if nothing work then its a motherboard problem.
goodluck,takecare.
Posted on May 08, 2008
SOURCE:
CMOS battery Sony Vaio PCG-4G1L
Instructions
    • 1 Open the Vaio screen until you can easily access the keyboard.
    • 2 Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers.
    • 3 Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer.
    • 4 Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side.
    • 5 Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard.
    • 6 Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart.
Jan 12, 2014 | Sony VAIO FX150K Notebook
Battery in my VAIO not recognized
The battery may be dead. How old is it? A battery has a "lifecycle" of sorts, just so many charge/discharge cycles.
Dec 27, 2012 | Sony VAIO Notebook
When you turn off the computer the clock stops.
if it is the CMOS battery that is not working, then it is already for repair..
you may also call sony parts center to check if you can buy it 8004887669
Feb 01, 2010 | Sony VAIO TX750P/B Notebook
Turn off actomatically, cannot turn on so far.
Your battery may be too low to allow charging it and "starting" your computer at rhe same time.
Remove the battery and clean the contacts on the battery and the laptop.
1. Plug in the laptop power adapter with no battery in the laptop.
2. Turn ON computer. It should stay turned on.
3. After Windows settles, insert battery.
4. The computer will stay powered on.
5. Allow to charge.
Sep 08, 2009 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
I've lost the base drivers for my vaio ar630e during the installation of windows 7 rc. Need help with restoring it back!!!!
If you have a windows disc that came with the system, insert the disc while the computer is on. Shut the computer down. Turn computer back on. Your computer should boot to the disc. Delete partitions. Format the hard drive. And reinstall.
If you do not have a windows disc contact sony to purchase a recovery disc.
esupport.sony.com/
Jun 24, 2009 | Sony VAIO VGN-AR630E Notebook
System recovery #2 doesn't work
take out recov disks and do this to restore ur system to factory default all data will be wiped off from C:
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
tell me if it helped and rate me well or ask for more!
Apr 08, 2009 | Sony VAIO PCG-V505EC Notebook
Sony vaio will not come on
Check your power supply
Take out your battery and try again
Try inserting the recovery Disk. Insert your os cd and hit the power button again and see what happen.
Oct 27, 2008 | Sony VAIO VGN-FS760 Notebook
Wont turn on
plz re insert laptop battery
put charge the lap top
n also i tink there is problem in power supply.
for help call me +919441133420
kishorechowdary
May 04, 2008 | Sony VAIO VGN-FS640W Notebook
Sony VAIO PCG-K35 Notebook Logo
106 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
