Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Filtered water after heated to make tea looks like mud
Our ice cubes have a sedament when they melt and when I try to make tea with the water out of the dispenser it is terriblie cloudy and looks like muddy water. We have changed the filter and it still does that. How can we fix this problem. The refrigerator is a Whirlpool and is only a year old.
    President:
  • 3,433 Answers
I dout it's your refrigerator causing the sediments and discoloration. Cooling the water is cause separation of suspended solids, but one would think your filter would handle that problem. Check the filter to ensure it is seated properly and not bypassing. Inspect the filter for decomposition ( coming apart) I've seen filters installed with the paper wrapping not removed. :-) Now that will cloud things up and provide a great deal of floaters.
Posted on Jun 01, 2010
I have no manual and I want to make ice cubes and be able to drink filtered water. I do not get any ice cubes when I switch the button on in the left rear. I am not getting water. I have removed, to...
1. Keep freezer temp setting @ 5 degree.2. Check water supply with full pressure (Back of regrigerator) 3. Confirm shut off arm is not struck due to huge cubes stored in bucket. If so, please remove ice cubes.4. Check solenoid valve which allows water flow whenever required to ice maker is working.
Please follow the steps also given hereunder.
Close the freezer door completely. The dispenser will not work while thedoor is open. Place the ice bin in the proper position. Avoid placing ice inthe bin that was not made by the ice maker. The cubes may jam in the deliverychute. If ice is jammed in the delivery chute, remove it with a plastic utensil.Discard the ice in the bin and wash it if ice has melted around the auger. Drythoroughly before replacing it. Wait three minutes if the dispenser stopsdispensing ice after the arm has been held in for a long time. The dispensermotor will reset and will begin to dispense ice again.
Thanks
Jan 29, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
No water to ice maker
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues.
If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Aug 11, 2008 | Refrigerators
Ice maker quit working
Remove the ice bucket. Look for jammed ice cubes in the mold. Get out a hair dryer. Heat that ice mold up till the cube melts and you see rotation. Make sure any fouled cubes are cleared.May take 5 to 10 minutes.
Sep 07, 2010 | Frigidaire Refrigerators
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Is it true that if you remove the white box where the ice cubes fall into, that it will stop the ice cubes from being made? I am interested in temporarily stopping the ice cubes from being made (4 months...
Removing the box may stop ice making on some refrigerators but not all. Look for an on-off switch inside your ice maker. Turning it off will not only stop the cubes from forming but in some cases will also stop the freezing action so you should remove any cubes that are there or they will melt and the melt water will run out of the ice maker. If there is no on-off switch you can raise the sensor arm up or block the ice detector beam to trick the ice maker into a "full" mode. That will stop the ice making function but not the freezing function. You could also turn off the water supply to the refrigerator if you do not need the water dispenser to work when you are not making ice cubes.
Oct 16, 2009 | Refrigerators
Ice maker doesn't turn out the ice/ tray fills with water, and freezes, but doesn't turn out the ice into the door dispenser.
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
  • At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
  • The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
  • Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself (see How Refrigerators Work for details). The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit (see How Home Thermostats Work for details on this operation).
  • Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
-->The icemaker has a heating coil underneath the ice mold.
  • The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
  • At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
  • The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
Jun 07, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore Ice Maker
Ice cube stuck in mold. Solution get out the hair dryer and heat up the mold till it harvests. Time will tell if the maker starts doing right again but I bet you it does!
Aug 03, 2008 | Whirlpool 21.8 cu. ft. Side-By-Side...
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
