Question about Dynex DXOP7CC (CrossCut) Shredder
Does not work; nothing appears to be stuck in the blades. is there a way to reset the machine?
    President:
  • 1,335 Answers
There is a switch that needs to be tripped when you put the cutter on top of the basket. Generally there is a tab on the basket that meets the cutter top switch. Check to make sure that the switch is being engaged when the cutter is placed on the basket. This occurs when either the cutter is put on the casket backwards or miss aligned on the basket.
Posted on Jun 01, 2010
How do I fix my hedge trimmer?
The outfit that makes the blades go into motion appears to be worn out. If its an older machine it will cost more to repair than its worth. The motor runs but the gizmo that the motor turns won't work. the blades like it should.
Jul 20, 2016 | Garden
My whirlpool was stuck on the Lock switch. we used he cancel button but now it wont run. the fill light come on but nothing happens. I have tried unplugging it to reset the panel, but nothing helps
Double check there is power at the outlet. If no power, check circuit breaker box. If the circuit breaker "pops" after resetting, you have a serious electrical problem in the washer or wireing to the washer. Consider the age of your washer, cost to find a lightly used working replacement, vs the cost for repair tech. Ask for an approximate repair visit cost.
Jan 20, 2015 | Whirlpool Washing Machines
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
Is there a reset button on the Badger 5
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Aug 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Cricut personal blade appears to be dragging
Have you checked to make sure the blade is inserted all the way??
May 22, 2009 | Provo Craft Cricut Disney Font Cartridge
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Paper jam msg. in Canon mp530; doesn't appear to b a jam though
look for a paper jam in the front and the back of the printer. open the compartments and take a look. if all is clear unplug the printer and then plug it back in. this will reset it. good luck.
Jan 16, 2009 | Brother MFC-3240C All-In-One InkJet...
Kicthen Aid Coffee Grinder BCG100
The two small little guides you refer to are a pair of switches that get depressed when the top is pressed down. In the top is supposed to be a plastic pin in the top of each one of the grooves. When both pins push both of the switches down (look like black dots) the grinder wil operate. The proper solution would be to replace the top.
May 24, 2008 | KitchenAid BCG100 Electric Blades Grinder
Dynex DXOP7CC (CrossCut) Shredder Logo
400 people viewed this question
Top Dynex Office Equipment & Supplies Experts
tony wahlman
tony wahlman
ray gallant
Are you a Dynex Office Equipment and Supply Expert? Answer questions, earn points and help others
