Question about Car Audio & Video
I have a zapco model PEQ board and i need the cable/wire wiring instructions can you help me?
The plug consists of a 7 pin plug which contains a ground, a hot lead for the PEQ itself, a neutral for the PEQ, and a hot and negative for each L and R channel, respectively. I had mine changed to RCA's years ago by a local shop, then soldered the connections myself after the proper connections were changed at the shop. I now have the signals changed into a Symbi-Link Transmitter/ Reciever System (unbalanced to balanced inputs) and am able to de-tune the PEQ and still get more output. It's fun... Hope the info helps.
Posted on Jan 16, 2011
How do i reset kicker kx 850.2 from protect mode ?
If it goes into protect and your speakers and wires are good, chances are you have bad output transistors that will need to be replaces.
May 12, 2014 | Zapco Reference 750 Car Audio Amplifier
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Nov 03, 2013 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Feb 04, 2010 | GE Profile Stainless Bottom-Freezer...
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
What is the wiring orderfor the zapco seq
the basic wirings are for inputs, power and for the speakers (front and rear). If you open up the device and trace the wires to the fader control (electrically), those are for the speaker outputs. The power supply line is much easier to locate through the power capacitor..maybe. watch out for the remote wire if it has one (this triggers the device to power ON). gudluck!
Apr 10, 2009 | Car Audio & Video
Zapco 18 band eq
You will need to call the manufacturer, ZAPCO - 209-577-4268, or email them at tech support robert@zapco.com , in order to purchase the part you are missing. It is possibel to hard wire the RCA parts you need and creat a homemade fix, but in all honesty it is not worth it, and it will probably introduce a lot of interference in to the quality of your signal path rendering it a bad option. Give them a call / email. If they will only sell the part to a dealer, call Car Depot @ 615 - 269-8080 and they can have the part purchased and delivered to you for a small fee. Good luck.
Feb 01, 2008 | Car Audio & Video
Car Audio & Video Logo
457 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
