Question about Coleman Refrigerators
Belle Minimix 150 runs 10 mins then motor stops
Belle Minimix 150 cement mixer runs 10 mins then motor stops and buzzes, itstarts again after rest
5 Suggested Answers
  • 251 Answers
SOURCE: workshop manual for belle minimix 150
http://www.islandhirecentre.co.uk/docs/spares/B10201.pdf
to get any engine drawings i would need the engine model from the side casing
hope this helps
Posted on Oct 23, 2009
erpaalai
  • 999 Answers
SOURCE: Why is my fridge buzzing?
The compressor is trying to start. The overload kicks out and then it takes 10 min or so for it to cool enough to try starting again. It could be a bad start relay or a broken compressor.
Eric
Posted on Nov 08, 2009
SOURCE: iv'e got a belle cement mixer 150, i think the
i have a belle 110v cement mixer just over a year old.Everytime i use it ,it switches itself off after mixing 2 barrows of concrete but it will run perfectly for hours when empty.(tryed this out on Monday)So therefore it only switches itself off when loaded.
Gets very hot quickly.
Any suggestions would be much appeciated.Brian
Posted on Jul 28, 2010
SOURCE: I need wiring diagram for
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Posted on Oct 21, 2010
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
HOW TO FIX PETROL MIXER STARTS THEN CUTS OUT
problem will be dirt or water in the carby that is blocking the main jet
overhaul the carby,
check for fuel flow to the carby
Jun 25, 2016 | Belle Group Minimix 150 Gas
A belle cement mixer,wont stay on when start button is pushed,changed switch ,still the same?
Sometimes the most simplest of fixes is verifying that you have voltage at your outlet and that you have voltage getting to the motor.
Check the motor's overload button; reset if necessary.
Take resistance readings:
  • start capacitor
  • run capacitor
  • and motor
If anyone of their specs are out of whack, that's the component that is defective and will need to be replaced.
Mar 24, 2015 | Masonry Tools
Left my honda petrol cement mixer upside down and now it won't start. How to I get it to work again?
There is probably oil in the cylinder. Remove spark plug drain oil and fuel and get carb cleaner spray in to cylinder wait five mins and empty out. Refill crank case with oil and clean spark plug. Fill gas tank note it might smoke for about 10 to 15 mins as it burns off remaining oil.
Nov 02, 2014 | Food Mixers
Why does the motor cut out after 4 mins. running, and overheats?
Is the air way clear? It is not likely to be the brushes, possibly a dry gear box?
Jul 11, 2014 | Masonry Tools
I need wiring diagram for Belle 150 cement mixer 110v
Oct 09, 2010 | Garden
Iv'e got a belle cement mixer 150, i think the motor is on its way out, its around a 2007 model can you tell me if you can put new brushes in the motor if so how, or if i can have the motor reconditioned ?...
May 03, 2010 | Home Fencing
Workshop manual for belle minimix 150
hope this helps
Jul 30, 2009 | Hammering
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Refrigerators Logo
90 people viewed this question
Top Coleman Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Coleman Refrigerator Expert? Answer questions, earn points and help others
