Question about Sansui TDC2075 20 in. TV/VCR/DVD Combo
Tv turns on and immediately powers down. no
Tv turns on and immediately powers down. no picture at all. What is wrong?
Lcd sansui green ligth always on
Posted on May 03, 2014
    President:
  • 1,099 Answers
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High Voltage were detected.
Posted on Jun 01, 2010
What can be wrong
Is the t.v new or its been some years that you bought it?Have you checked the DC voltages leaving the power supply? If not, let's try that now.
Put your red lead on each pin leaving the power supply one at a time, with your black lead on any exposed chassis metal for ground. Stick that red lead down into the connector so the lead makes contact with the pin.
Be sure the TV is turned on.
It can be a fault in the screen if it is under warranty i suggest you contact the shop or supplier.
Best regards,
Daniel
May 10, 2014 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
When I power up thr TV it immediately poers back down BEFORE the screen shows a 'picture'.
I hate to be the bearer of bad news, but it sounds like the "over voltage protect circuit" is doing its job. There is a 130 volt regulator circuit in the power supply that limits the high voltage to around 30,000 volts at the second anode of the picture tube which limits the x-rays emitted from the crt. If the regulator fails, there is this over voltage protect circuit, which immediately shuts down the power supply and the TV. Turning off the TV resets the protect circuit. Turning the set back on, will cause the protect circuit to engage again. If you're competent in electronics, it is possible to aquire the parts and do a successful repair for under $20.00 in parts, but beware, there are a lot of dishonest people out there ready to take your money. Hope this helps! Dano
Aug 15, 2011 | Zenith C25A24T TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv powered off and will not stay on. keeps powering off
Not an easy one this. But modern TV's monitor themselves if there is something it doesn't like eg power supply not giving the correct voltage, the TV will shut down. Not really a solution !
Jan 15, 2009 | Zenith R45W47 45" Rear Projection HDTV
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sansui TDC2075 20 in. TV/VCR/DVD Combo Logo
141 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
