Question about Aquabot Aquaproducts Automatic Swimming Pool Cleaner Ne350
Aquabot wont pump or move, intermmittent
Hello;
I noticed my Aquabot shutting down periodically during use. I keep resetting it, but sometimes it just sits there. I have tried resetting the circuit breaker, unplugging/plugging. cleaning the filter bag.
The transformer box lights up , indicating power. It will occasionally start moving again but mostly just sits there.
Any ideas? thanks!
  • 12,061 Answers
Well either you have a jammed up motor, or a bad motor, or the Controller unit has faulted.
http://www.robotshop.ca/PDF/aquabot-turbo-t2-manual.pdf
Above is a manual, this should help you it has exploded diagrams to help. There seem to be many ways that it could get tangled up, or maybe the belt has come off, any way it's about time to A: Get a screwdriver, or B: Call a service man....
Posted on Jun 01, 2010
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Sometimes when i am on the treadmill it would just shut down. it did this several times and now it just completely shut down. there are no lights. i am going to try and change the fuse but i dont think...
Dear Sir:
The treadmill shut down for protect itself, the electronic desig had been design for to protect the electronic component. The problem is the the friction between deck vs belt, that put enough friction, and the machine shut down.
TRY to run your software calibration, for easy diagnose and troubleshooting.
See my TIPS, for easy diagnose and troubleshooting.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Jan 05, 2012 | Exercise & Fitness
What's your problem?tread mill stop working belt stopped turning
Dear Sir:
Hello I hope you are o.k
After Reading your problem, I will help you please follow the next step:
Your problema is Electrical:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
If you have questions, email us at doc@treadmilldoctor.com
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if
equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix (that we don't recommend) try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact me with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel . Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or a console.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
At smog shop guy says 4 problems saying not ready go drive car for 50 miles.did that and still saying not ready
The car has to go through a certain number of driving cycles (start, drive, shut down) after the computer has been reset or the battery disconnected for an extended period of time before it will be ready, sometimes 50 or more depending on the vehicle. You could drive 1,000 miles and it wouldn't make a difference. Take your car on multiple short trips, around 15-20 minutes each, letting it sit for a while in between. Just starting and shutting down the car won't count either.
Mar 08, 2011 | 2002 Ford Crown Victoria
I want to know the product key of ms-office 2007
If you purchased your office software online and downloaded it there should be a a product key with the online receipt. If not you need to register your product and they will give you the key. If you purchased you product after or during the the free trial period the software should automatically open up upon receipt of your credit card payment. try shutting down your computer and reboot it, sometime it needs to reset the code
Jul 21, 2010 | Microsoft Office Professional 2007 Full...
Not sure if the rtc error is the cause of my problem. Laptop will not boot up after it has been shut down for a few hours. It will turn on and get past the acer screen then simply sits there and does...
You are right on your first assumption...the RTC battery is dead and keeps resetting the cmos control settings. The operating system however is updated to the present and that is where things don't want to play nice together. Change the battery, boot the laptop in safe mode with networking, adjust the date and time. When the laptop loads and is stable, then try to reboot normally into windows.
Below is the link to the service manual for that laptop, you can either click on or copy and paste into the browser address bar. It is free to use, copy and print.
http://tim.id.au/laptops/acer/aspire%205050%203050.pdf
Jun 28, 2010 | Acer Aspire 5050-3242 Notebook
My tv shuts off after only two minutes
try using a master reset to fix this.
Sometimes after being used for awhile electronics tend to malfunction.
press and hold these buttons in this order....
power / volume up / channel down.
The tv should shut off after doing this.
Turn it back on manually.
This will reset the TVs internal memory chip.
I dont guarentee this as a permanent fix....but it worked for me.Good luck
Sep 19, 2009 | Sansui DTV2760 27" TV
Keeps tipping over
With these automatic pool cleaners, this is often a problem with the treads or having air in the head. Make sure that your treads are not worn and are getting proper traction. If they are worn, you might need to replace. To rid the air, try turning the Aquabot upside down and submerse in the pool for a few minutes. This should force the air out.
Jul 12, 2009 | Aquabot In - Ground Robotic Pool Cleaner
Aquabot goes in one direction
Find a looooong straight area and, starting from the Aquabot, hold the cord straight and straighten it out by letting the cord twist so it isn't all gnarled and twisted - move down the cord, always keeping one hand firmly on the end of the cord closest to the machine (to prevent it from re-twisting). You'll find that the cord will spin like a top as you get closer to the end. Once untangled, pull down on the metal rings under each end of the top floating handle (may require a pull and a slap against the handle). MAKE SURE THE HANDLE IS LOCKED IN A DIAGONAL POSITION.
Jun 17, 2009 | Aquabot Turbo Robotic Pool Cleaner
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Aquabot Aquaproducts  Automatic Swimming Pool Cleaner Ne350 Logo
727 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
