Question about Databecker PDF Producer for PC
I am unable to uninstall PDF Producer Proffesional after migration via PC Mover to Windows 7 and it is not operating properly.
    President:
  • 2,340 Answers
Option 1: You can purchase the "Final Uninstaller" a system utility to remove the unwanted software ie incompatible to your new OS or
Option 2: Delete the Folder from the program files and use the registry cleaner to clean the remnants.
Note:- If you are not so tech savwy use Option 1
Posted on Jun 01, 2010
EXITING TALLY!! INCORRECT VERSION. DATA OF INCORRECT VER.(8) CAN ONLY RUN VERSION 7
check if the version you are using on both the computers are same. If they are same also check for the release. If there is difference in the version and relase it wont work.
Try migrating the data from lower version to higher version or use same release on both the pc
Apr 22, 2014 | Microsoft Windows 7 Professional for PC
Tip
Windows 7 Migration Guide. Minimum Hard Requirement · 1 gigahertz...
  • · 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • · 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • · 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • · DirectX 9 graphics device with WDDM 1.0 or higher driver
Versions of Windows 7
  • · Windows 7 Home Premium
  • · Windows 7 Professional
  • · Windows 7 Ultimate
Select either 32 or 64 bit Operating system (Based on requirement)
Last but not least select viable Windows 7 Migration Software.
on Dec 16, 2009 | Microsoft Windows XP Migration Services
Hi I have a xp proffesional os the device manager indicates a yellow exclamation icon SM Bus controller and unknown devices. triend to find the driver in intel and asus support site but cant find the...
Try going to the system manufacturer's site and look for updates,
(however, you really should upgrade. Windows 7 works well, migrate your data while the old system still operates, and everything gets put away correctly. New hardware works significantly faster than XP era hardware....Hate to put $$ into older system.)
Feb 12, 2011 | Computers & Internet
When starting PC, appearing message "please wait while windows configures nero 7 ultra edition"
The most probable cause is that you have not properly installed or uninstalled Nero 7 Ultra Edition in your PC. Try properly installing or uninstalling the product again.
Dec 12, 2010 | Dell Computers & Internet
Unable to connect to internet on broadband, keep getting error message 651, Win 7. No problem prior to loading Win 7, used to have Vista Ultimate.
This a well known bug in Windows 7 specially when you migrate from Windows Vista to Windows 7.
The cause is a file "raspppoe.sys". This file will be found on the partition you have installed your operating system If it is C: partition then it is found on C:\Windows\System32\drivers.
To fix this bug simply rename it as shown as follows
(1)Rename this file from "raspppoe.sys" to raspppoe.old or any name it any name of your choice.
(2)Once this done simply restart
Nov 11, 2010 | Microsoft Windows Vista Ultimate Edition
Need update for Windows 7
Successfully reloaded my PDF Producer in Win 7 environment. Key - need to skip autorun file and run in troubleshooting/compatibility mode using administrator permission.
Insert the CD and open with explorer. Move to the setup directory and run setup.exe in troubleshooting mode. Accept default to use win XP model and let the installer run. It took several minutes for the install screens to sort themselves out and begin the process, so give it enough time to figure out your OS and antivirus environment.
Aug 19, 2010 | Databecker PDF Producer for PC
Does Toshiba Satellite A45-S1202 support windows 7 proffesional?
Yes but all these new OS ****. You should be XP !!
Unless you have over 2gb ram :)
XP is so stable
May 22, 2010 | Toshiba Satellite A45-S1202 Notebook
Use to be able to scan a document and save as a PDF, got new computer with windows 7 now I'm unable to save as PDF
you need to use the driver for win 7. If you have already installed the software using the installation cd, you need to uninstall it first before using the win 7 driver by going to start menu > programs > lexmark 5600 series > tools> uninstall. Then reboot pc. Check the version of your operating system. Right-click on My Computer and choose properties to see if you have a 64-bit or 32-bit OS. Download the proper driver package by going to this link: http://bit.ly/cclHPL . download cj5600Win7en64.exe is for 64-bit OS. or download cj5600Win7en32.exe for 32-bit OS. install the sw and try scanning again. Hope this helps.
Mar 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
I have jvc everio model gz -mg70u unable burn dvd on my pc with
Need software update for vista, go to jvc web site and check for software up dates.
Jan 01, 2009 | JVC Everio GZ-MG21 Camcorder
Databecker PDF Producer for PC Logo
88 people viewed this question
Top Databecker Computers & Internet Experts
Lawrence Oravetz
ray gallant
Are you a Databecker Computer and Internet Expert? Answer questions, earn points and help others
