Question about Lasko 3300 Wind Machine¿ Floor / Box Fan
Need wiring diagram - wires broke off when cleaning bearings
I need wire diagram for my compaq presario cq56
Contact Compaq/HP support and ask. Include pics if possible.
Apr 26, 2014 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Need to know the diagram in wiring the sunroof in 1994 toyota camry
how to wire it , the motor plugs right in, there is a connector for the wiring .i will see if i can give you a wiring diagram, lets see......okay here is the wiring diagram for your 1994 toyota camry, hope this is helpful, good day....10_1_2012_5_54_49_pm.gif
Oct 01, 2012 | 1994 Toyota Camry
Not draining
see this possibles causes:
Drain line/air gap
see for clogged pipes, and repair see the diagram
Pump
test for defective pump
Drain valve and/or solenoid
try to lube the solenoid
Belt
see for worn belt
Motor
test for input voltage, bearing, burn
Timer
see for defective time, clean with special spray contact, tight wires, see for burn wires, and break wires.
5_9_2012_11_40_30_am.gif5_9_2012_11_40_49_am.gif5_9_2012_11_41_09_am.gif5_9_2012_11_41_30_am.gif
May 08, 2012 | Dishwashers
I need to replace the power switch on a Lifestep 9500hr and I need the wiring diagram
1) you do not need any wiring diagram for to this.
2) Since you will not find any wiring diagram for your treadmills, only if you pay for service manual at your company dealer.
3) I can recommend you very easy: the following.a)buy the switch to radio schack.
b) Put in your machine c) desolder one wire and put in the same place in the new one swithc and go on, and ready.
Anyway see the block diagram for your information.
sincerely.
ernesto cuadra
Dec 17, 2011 | Exercise & Fitness
I need a wiring diagram for my iTrip. The wires broke off at the plug that goes into the iPod. I'm not sure which wire,( green, orange or red ) is the ground wire. Trying to fix it myself. Thanks for any...
@dpettus88
I had the same problem. The plastic harness around the connector broke after I had the iTrip for only a few months. It finally quit working recently. I was amazed to see how cheaply made this somewhat expensive item was when I finally took it apart. Anyways, here is what I came up with. There\'s a bit of whine in the signal, which I believe is because my soldering on the yellow and brown wires left a little to be desired. But, as I said, this configuration did actually work. Will post results of cleaning up the connection on those two pads.
Dec 09, 2010 | Griffin Technology iTrip Auto with...
Need a diagram of wiring for a gas wall oven to
As far as I know almost all kitchen appliances have a wiring diagram of all electrical connections. usually found on either of the side panels(if they are removable) or inside the control panel where the temperature and the rest of the knobs are located, but if yours does not have one you will need your oven make and model number and refer to the following websites for the diagram : www.partselect.com or www.repairclinic.com.
Jan 29, 2010 | Ovens
NEED TO REPLACE THE GROUND WIRE TO THE STARTER ON A 99 FORD F250 LIGHT DUTY WITH 5.4 V8 AND NEED A WIRE DIAGRAM
why do you need a diagram?, if you have a new one, just route and install it just like the old one.
Oct 14, 2009 | 1996 Ford F250 Crew Cab
I broke a bunch of the wires on the wiring harness
You need to get yourself a shop manual and rewire the harness in accordance with the wiring diagram in that manual. I bet if you look online you can download it for free like I did.
Oct 02, 2009 | Polaris ATV
Timer wiring order
there should be a diagram within the control panel, if but by looking at your post, you should NOT put the black and whites to one nad a vlac and white top another, they shouldbe on same terminal(s), whites are used for neutral, and blacks for line voltage.
Mar 04, 2009 | Maytag MDE3706 Electric Dryer
Lasko 3300 Wind Machine¿ Floor / Box Fan Logo
88 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
