Question about Sony Handycam DCR-HC42E Mini DV Digital Camcorder
Cassette tape will not load
I have a sony dcr-hc32. The mini-dv tape when loaded, will not retract into the camera. Is there a simple fix for this?
The Mini-DV mechanism will not retract with a cassette installed but will retract when empty. Any ideas please
  • Anonymous Apr 20, 2008
    Yes we have the same problem too. It will load properly when emptied,but when you insert a tape it will not insert. Getting rather frustrating.
  • Anonymous Aug 07, 2008
    My Sony DCR-TRV355E automatic cassette mechanism will not retract with a cassette installed but will retract when empty.
Meow
Posted on Jun 12, 2008
  • Edward Ho
    Edward Ho Aug 15, 2013
    Don't post irrelevant solutions.
2 Suggested Answers
  • 6 Answers
SOURCE: cassette tape will not load
there is a small motor at the lower right corner ( if you face the tape side of the camcorder). check if the motor reponds to a 5v voltage. if not, that is the problem
Posted on Sep 06, 2008
Problem with the Sony Handycam DCR-HC32 Mini DV Digital Camcorder Moisture condensation turn off 1 hour
It can be a tiny dew switch mounted on near the drum motor, Which you can change off values with a resisitor for the fault .
Also if you can blow hot air into the cassette tray this would enable the dew switch to open out.
Sep 28, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
I am sorry, No simple solution available for this problem. Your camera required new DV Mechanism.
Apr 07, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 22, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Tape holder of camcorder isnt closing
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Jul 19, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam DCR-HC42E Mini DV Digital Camcorder Logo
307 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
