Question about General Electric WSSH300G Front Load Washer
My machine doesn't run. Sounds like it's trying...
My machine doesn't run. When you hit start, you hear the motor trying to run, but nothing happens. Tried unplugging, different cycles etc to no avail. It's 3 yrs old.
  • General Elec... Master
  • 12,061 Answers
Http://appliancejunk.com/ge/washer/31-9135.pdf
Above is your service and repair manual, this is what the engineers use to troubleshoot and repair these units. Below, and two DIY self help washer repair self help websites. http://www.repairclinic.com/Washing-Machine-Repair-Help
http://www.washerhelp.co.uk/diy-repair-help.html
Posted on Jun 01, 2010
  • jfrespencer
    jfrespencer Oct 11, 2012
    This service and repair manual link is invalid.
Sta-rite 1 hp pump sounds like it is on but nothing is happening ? What is the solution?
Is the motor shaft turning??????? If not but you hear a humming sound, try replacing the start/run capacitor located at rear of motor under back cover..
Nov 14, 2015 | Pool & Spa
I own a wcvh6600hww front loading easing machine. I load the clothes, soap, etc...go to start the load. Hit power , choose my cycle, & then I try to press start, but nothing happens...the start/pause...
It sounds like it's gamed, the fact the button is flashing shows a major problem, turn off power, remove the motor still connected, if it runs o.k.the problem is the machinery, or vicer /verser, if it is jammed machinery take various parts off until things move.
Jun 28, 2014 | Washing Machines
Where i can find elecrical wiring diagram
When you try to start the bike, does anything happen? Noises? Clicks? Or is it silent and nothing happens? If you hear a click or it try's to start but doesn't turn over. If nothing at all happens when you hit the start switch then you most likely have an electrical issue, versus if you hear the starter click or try to start to bike, then that would mean a mechanical issue.
May 14, 2014 | 2008 Peugeot Geopolis 400
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
The machine will not aggitate or spin
sounds like your motor coupling has broken, cost about $20 for the part,can get from your local appliance shop! if you can hear the motor running on the agitate or spin cycle but nothing happens,more than likely the coupling has broken,
Jan 10, 2010 | Kenmore 24642 Top Load Washer
Frigidaire GLTF2940ES0 won't pump or spin
Sounds like a water valve solenoid. The hot and cold water is controlled by solenoids that open and close. Try running just the hot and just the cold. If one or the other works, then the proble,m is a bad solenoid valve
May 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I accidentally started sewing with wrong foot and needle hit the plate and broke. Machine won't sew
This is just a guess since I haven't seen exactly what's happening, but my guess is that the drive belt has come off. You can hear the motor running because the machine is attempting to bring the needle to it's fully up position. Since the machine isn't turning, the motor will run faster and faster until it hits full speed.
Apr 07, 2008 | Husqvarna Designer I
Will not start
bsolo, sounds like something jammed in your pump stopping the motor. You will have to remove the cabinet to get at the pump. It has 2 clips that hold it to the motor. The best way to tell for sure is to remove the cabinet, jump the lid switch and start the washer. If the motor runs without the pump, then you know for sure it's jammed. I will try to attach a diagram on how to remove the cabinet.6212c10.gif216ffff.jpg
Dec 06, 2007 | Roper RAX4232KQ Top Load Washer
General Electric WSSH300G Front Load Washer Logo
182 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
