Question about Onkyo TX-SR605 Receiver
HT-R550 Onkyo Reciever does not play sound
There was a brupp.. sound and there after I lost the all the sound from the receiver. checked transistor and relays, everything seems to be good. Can you tell me where exactly the culprit is.
Thank you.
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
shaggyrat
  • 1224 Answers
SOURCE: I can't get any audio
run everything to receiver each channel should work on own for audio
video to tv audio to input rca jacks
if have to much rca's for little bit of reciever input output rca's go out to walmart and buy a rca switch for sound
one side would be A the other side would be B
Posted on May 13, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
SOURCE: Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Posted on Apr 02, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
My onkyo reciever HT-R758 stopped working no sound . i have checked my speakers with other reciever and they are fine
If you are getting display screen properly after power on, try to factory reset the device (Check the user's manual provided with the unit)
Jan 02, 2017 | Onkyo Audio Players & Recorders
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have an onkyo reciever HT-S580,that I want to connect up to my TV & my Bell reciever to get my surround sound system working.Where do I get a visual
You can download the owner's manual for your Onkyo a this link:
http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s580_manual_e.pdf
It has drawings on how to connect just about what ever you want.
Good Luck
Feb 14, 2012 | Audio Players & Recorders
Onkyo ht-s5100 lost sound
Double check that the approtiate speakers (A or B ) are selected.
Jul 10, 2009 | Onkyo HT-S5100 Theater System
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
I can't get any audio from my PS3 through the HT-R550 I am trying to set up in my home. I have an HDMI cable connected/running from my PS3 into the reciever. I also have an HDMI running from my Plasma TV...
May 13, 2008 | Audio Players & Recorders
Onkyo HT R550 sound going in and out
Sh$T I had the same problem with an older model... went out and bought a new Onkyo... HT-R550 I have had it for 2 years as of January 2010
Dec 06, 2007 | Audio Players & Recorders
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
Onkyo TX-SR605 Receiver Logo
301 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
