Question about GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator
Chronic defrost problem: GE GSS25VGMB I have had a legacy of issues w/ the defrost circuit of my GE side-by-side. I got GE service the first and second time I had this problem: 1st time: Broken defrost heater element. 2nd time: Bad motherboard. (2 yrs later) For the sake of anyone reading w/ a problem, here are the symptoms depending on how long the problem has existed: Warm fridgeside top, frozen veggies bottom, possible frozen water tank causing no water to dispenser, technically warm but still frozen freezer, and best indicator: frost on back inside panel of freezer. The unit has gone on to consume 5 more motherboards, with each one lasting less time than the previous, the latest lasting 6 weeks. I have a warranty on the MB so this is not an on-going cost, but it is a major annoyance. There must be something else causing the issue. The heater measures at 22ohm. Not sure what else in the circuit I could change out w/ the MB this time. If I jumper the board, it will light the heater. Sick of defrosting manually..... Thanks
  • lloyds4 Jun 03, 2010
    Turns out that the evap thermistor thinks its 100 deg in the freezer. So it shuts down the defrost cycle before it even starts. The variable times between problems must be related to humidity levels in the air and how long it takes the coils to freeze over.
    Time to get a new thermistor and move on....
SOURCE: Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Posted on Aug 17, 2007
docjohn174
  • 943 Answers
SOURCE: Trouble Shooting Warm Fridge
hi thanks for the question .in the freezer a small disc with 2 wires going to it that's the defrost termination switch if a fail will not let the to come on . replace it thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
SOURCE: GE side by side. Freezer cold, fridge kinda cool
i had a similar problem, i found that the small mast on the motor turning the fan was just spinning and the fan was spinning just a little bit because it sits on there. I took the plastic fan off and put tape around the mast of the fan motor and placed the fan back on so it sat on there tightly. The fan blew cold air again because it was able to **** up the cold from the coils again, compared to when it was very loose.
Posted on Jul 07, 2009
mgprice
  • 744 Answers
SOURCE: My freezer was developing frost / not cooling very good.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 29, 2009
Pss26msta - freezer will not cool below 19 - 20. Refrigerator will not cool below 42 - 46. any suggestions on where to start?
The defrost circuit and the evaporator fan motor. The defrost circuit includes the main circuit board, the defrost heater, and the defrost heater safety.
Oct 07, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE GSH25JFTFBB side by side is not defrosting properly. I have already replaced the motherboard & defrost heater element, and have manually defrosted several times. Evap coils continue to frost over...
This is a chronic problem with these...
It could be either of those...they are not that expensive, so it may be worth while to replace both...
Parts #240 and 241 here
heatman101
Jul 08, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE - GSS22IFPHBB freezer is working, but my fresh food part is not cooling. How do I determine what exactly is wrong?
xz555
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cold
Your problem could be a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
The compressor motor on our GE Profile side by side has been making a loud banging sound when it shuts off. Now, it doesn't shut off at all. I notice some ice formed in the back of the freezer.
two seperate issues,the springs within the compressor housing that support the piston have broken,can only be resolved by replacing compressor....in regards to the ice build up,you have a defrost problem.defrost issues can usually be resolved for about 120-160.00 through a qualified servicer
Mar 06, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Our GE PSC25PSTA fridge drips water from the icemaker
I have this model also for just over 3 years and it developed the same problem. The issue turned out to be the unit was in defrost mode too long caused by a failing control circuit board (found in the back under a panel cover). The board controls all refrig functions. This was replaced and the unit works normally now. The board costs around $200 plus the service call ... still cheaper than a new refig.
Feb 09, 2010 | GE Refrigerators
GE GSL22JFPC side by side fridge...ref side warm(suddenly) and freezer starting to defrost. I pulled the fridge from wall cleaned what i could...is this fridge shot?
What temps. do you have in the freezer and the fridge sections?
Are both the compressor and the condensor fans running?
Can you put a thermometer in there?
This could be a compressor,evaporator fan, defrost element and or a circuit board issue.
Sep 15, 2009 | GE Refrigerators
GE side by Side - dead, again
check defrost timer . plug in and turn timer manualy and see if unit starts running. This means it was in a defrost mode which occurs twice daily.
Feb 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge rifrig will not defrost
you have a defrost issue not being able to verify circuits on the mother board i would replace the high limit, what you are calling the termination stat this stat stays closed unless the temp hits 140, thats right 140 degrees f and change the evaperator sensor.
evap sensor can cause missed defrosts or no defrosts
high limit part number wr50x10068
sensor number is wr55x10025
each part is 7-15 dollars each
Apr 07, 2008 | GE GSS20IEP Side by Side Refrigerator
GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
