Question about Janome Memory Craft 5700
My problem is the thread off the needle goes down and around twice then gets stuck on the feed dog teeth I think stopping the machine.and making the thead ball up
  • 40 Answers
Check the machine for proper threading, this can cause issues.
Posted on Jun 01, 2010
Singer 6235 - the fabric is not advancing regardless of stitch length or tension
Could be any of a multitude of reasons.
Check whether the feed dogs are actually rising 'above' the needle plate. If not, then they may be in a dropped position used for darning and free motion quilting.
Sometimes the feed dogs and the mechanism underneath is jammed with lint and debris. Make sure the dog teeth are well cleaned. Also check if the tips of the teeth are worn. Also verify that the needle plate is flush with the free arm--if it is raised, it will prevent the feed dogs from doing their job.
The other thing to check is whether the machine has a presser foot pressure adjustment. Some machines have it, others do not. On newer machines, it is usually a dial somewhere around the left side of the head or toward to top of the head. On older machines, unfortunately, some are simply a big screw head on the inside of the case directly above the presser foot bar. It basically applies more pressure to the presser foot, which in turn applies more pressure to the feed dogs. The problem will usually show up when sewing either very heavy or very fine fabric. Perhaps trying a different presser foot will make a difference.
I don't know what is the highest number the stitch length goes to on your machine, but a #2 stitch length is pretty short on mine. Try setting it higher.
Sewing Machine Presser Foot Stuck
Singer 6235 User Manual
Nov 19, 2017 | Singer Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
I was sewing and my machine locked up. Its a 910 bernina
Does the hand wheel turn ? Does anything move when you turn the hand wheel ? If not, may be a mechanical seizure, usually from overheating or maladjusted gears.
It may also be a seized thread. Thread may catch in a burr in the needle, or a burr in a thread guide. Check the entire thread pathway, make sure no loose thread is caught anywhere, there are no rough spots or burrs in any guide. Clean lint out of the bobbin area, and under the feed dogs. Make sure the thread hasn't wound around the spool pin or spindle, which can cause an abrupt stop in stitching, though it usually also breaks the thread and sometimes the needle too.
Clean it thoroughly, unthread and rethread. Those are always the first steps if something goes wrong. If you can get it moving and it happens again, turn the hand wheel slowly and watch to see if the thread is popping out of any thread guide, or out of the tension adjuster.
If the hand wheel won't turn, it may well be seized gears, which may be a costly repair. You can open up the machine and look inside to see if any gears are stuck, or missing teeth.
Do you oil this machine regularly ? All machines should be oiled periodically. If you use it a lot, oil more often.
Oct 09, 2014 | Sewing Machines
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
My thread gets stuck down in the bobbin area.
Ensure that you are threaded correctly, set your tension for roughly 4.5 and "floss" your machine when threading by grabbing the thread by the needle immediately prior to threading the needle with your left hand, and the thread on the top by the spool with your right hand; then pull the thread back and forth briefly.
Ensure that your bobbin is in the bobbin case in the correct orientation.
Ensure that your feed dogs are in the "up" position. Many inexpensive machines do not have the option to drop the feed dogs, and I believe your kenmore to be one that lacks the option, but consult your manual just to be sure.
Also make sure you're using a good quality thread. Use a European thread, and definitely avoid anything from the dollar bin or any kind of "dual duty" type thread. Cheap thread causes nasty nasty things to happen to sewing machines.
If none of these fixes solves your problem, let me know; but going through the above will solve 99% of problems like you're describing.
Good luck,
-R
Mar 11, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
