Question about GE 19.5 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
Water pooling in the bottom freezer
Frozen water has collected in the bottom freezer. its coming from the center not by the ice maker. wondering if the defrost drain is froze up. thanks
    Problem Solver:
  • 13 Answers
You most likely have a blockage in the condensate drain line.You should turn off the frig.and empty the freezer,take a hairdryer and melt the ice on the bottom of the freezer.somewhere in the back on the bottom you will see a small drain under the evaporator.you may have to remove the cover of the evaporator to find it.once you locat the drain its just a matter of blowing out the line with a piece of 3/8ths plastic tubeing.
Posted on Jun 01, 2010
Hsm25gfra sa. Bought used, was told ice maker didn't work, so haven't hooked any of that up. Problem: water/ice is pooling in the bottom of the freezer section. Every day or two it leaks out. I'm...
The refrigerator has a blocked condensate drain line. In most Hotpoint models it is easily accesed by pulling out the bin at the bottom. There should be a drain grommet at the center of a trough in back. This plugs up. You may have to pour hot water the thaw out the ice and then either blow out the drain tube or I use a 5/15 plastic hose and push it through the drsin to clear it out. this should fix the problen for a long time. Food particles etc. collect in the drain and ice forms around them and blocks the drain.
May 17, 2014 | Hotpoint HSS25GFP Side by Side...
I have ice building up in the bottom of the freezer even with the ice maker off. Where is the water coming from and what is the fix? I can see a slight trail of ice down the back behind the ice maker and...
From what you described the defrost drain trough is frozen up. The drain tube or the opening in the drain trough is stopped up with some sort of debris and is frozen over.
Each time the freezer goes into a defrost cycle it melts the ice on the coils and the water has no place to go. The result is that water will leak into the freezer compartment, collect on the floor of the freezer and freeze solid.
Mar 20, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
I have a problem with my freezer, it has water pooling then freezing in the bottom of the freezer. The water also runs out onto the floor. It looks to be coming out of the opening in the back of the...
Your defrost drain line is clogged and frozen over with ice.
Turn off the fridge. Remove the bottom freezer drawer. Take a hair dryer and thaw the drain hole at the back bottom section of the freezer. After you defrost the drain line pour 1/4 cup bleach into the drain hole.
Jun 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water pooling and freezing in bottom of freezer. I've shut the valve so no water is going to the ice maker but water still collects. I can't figure where the water is coming from. Can you help? Thanks!
Sounds like the drain from the freezer evaporator coil is plugged causing the condensate to overflow and fill the bottom of the freezer then refreeze. Most freezers have a drain line from the evaporator to the bottom of the refrigerator leading to a collection pan to allow evaporation of the condensate. You may be able to access the evap condensate pan by removing the rear panel of the freezer. I can not say for sure without the specific model of the unit in question.
Jun 23, 2009 | LG LFC25760 French Door Refrigerator
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
GE 19.5 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
141 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
