Question about Yamaha 12V Air Pump
My '94 yamaha waverunner 3 runs great for the first 30 minutes. After that it will run fine at idle and just above but the rest of the throttle it just bogs, like it is running out of gas or has some kind of rev limiter
Could be a bad temp sensor. The bog is a rev limiter to keep engine from running full throtle when hot or when there is another problem. You can bypass the temp sensor and see if that takes care of problem. The parts about 100.00. I disconnected mine a now run a temp gauge which I mounted on the right side just above oil gauge.
Posted on Jun 20, 2010
  • Surfcreatr Jun 20, 2010
    P.S Be sure not running hot. You should be able to touch manifold when in water without burn!
  • george randolf lee Jul 20, 2012
    HELLOW I JUST BROUGHT 1995 WAVERUNNER 111 IT SAT 7YRS CHANGED STATER AND FIRED RT UP WE PUT IN THE WATER AND IT WOULD RUN THEN START SPUTTING COULD THIS BE THE PROBLUM THANKS IF YOU CAN HELP
I have carb problems with my 2004 Yamaha 200 TW.
Hey MPCD.. Take the carb to a QUALIFIED PROFESSIONAL.. they can fix it...
Aug 08, 2017 | Yamaha Motorcycles
Runs but will not get up to speed. When you first give it throttle it will take off fine, at first, then it bogs down to rough idle if not shutoff.
have you got any water in the fuel tank ?? very basic ski 2cyl 2stroke ! i recomend stripping the carbs and clean and check the diaphams have not gone hard also ! dont try and run it to clear the problem because if one carb shuts off the fuel feed then you will melt a piston !! then boo hoo no more play time !
Apr 02, 2014 | Yamaha 2004 WaveRunner XLT 800
Yamaha waverunner 1200RECENtly purchased wave runner took out for 4 mile trip ran great took in for evening done inspection and realized it didnt have oil pump only a plate were it should be. so i put some...
The first thing to check would be the compression. As long as both cylinders are with in 10 psi of each other you should be okay. Both cylinders need to be at least 100 psi. That would be the minimum for a motor to start and run. It should read aprox- 150 -- 165 psi. Also i would check for a possible exhaust leak, that would cause the motor to bog down because the carb is breathing in the exhaust fumes. Try running the motor with the hood up to see if you have a leak.
Mar 11, 2017 | Water Sport
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
MY YAMAHA WAVERUNNER 3 RUNS GRATE FOR ABOUT THREE MIN AND THEN ACTA LIKE THE REV LIMITER KICKS IN IVE REPLACED THE COIL AND OVERHAULED CARB ANY HELP WILL BE THANK FULL 1992 650 YAMAHA WAVERUNNER 3
You should check your feul filter or maybe the feul tank it could be you have trash in your tank and it takes a few minutes to pick up the trash and restrict feul flow possibly not clogging the filter all the way allowing just enough feul for it to idle
Jul 08, 2009 | 1979 Yamaha XS 500
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
1,786 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
