Question about Seth Thomas St. Thomas Creations Daytona Dual Flush Elongated Toilet Bowl - 6145.223.02
Water level is going down, in tank. How do I adjust?
    Scholar:
  • 81 Answers
Try this link first. It will not give you the answer but gives you an email address that I would expect would be of help.
http://www.stthomascreations.com/CustomerService/
Posted on Jun 01, 2010
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
Have a new 400A and water level is normal in the tank : upon flushing the bowl fills almost to an overflow?
What's wrong with that that's were it should be.with a 2.5 gal tank that water level is corect.Iff think that's too much, adjust the water level adjust clip, by sueezing clip and move it down to adjust the water levelto lower.
Sep 10, 2014 | Fluidmaster 400A Toilet Fill Valve Cap
How to adjust water level in totoST743S toilet
most of these have a screw adjustment on the fill assembly inside the tank...screw up or down to adjust....try one way or other to see which works
Sep 08, 2014 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
The water level is too high in my tank and goes over the over flow and in styrofoam on the inside of the tank.
Adjust the float attached to the fill valve. Some simply slide up and down on a racheted adjustment bar. Others screw up and down for adjustment. Flush after each adjustment until the proper fill level is acheived. Make sure there is still a sufficient amount of water at a given level to flush the toilet properly.
Dec 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
OUr 5 yr old duravit toilet is constantly running. Seems that tank water is seeping into bowl causing the mechanism to demand more water. Onl way to stop is to turn of water valve until we need. Before I...
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case   a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 16, 2010 | Duravit Tribeca US-Type Elongated Toilet...
I have the Kohler toilet with the top actuator, it flushes fine but won't stop running. If I lift the tank top I'm making the toilet flush again. Can this be fixed or do i have to replace the whole system?
(Problem 1) if you can see the water running in the bowl it's a good chance that the flappers warn. you'll have to look at the angle where the light hits the water. The water will be rippling where the top of the water meets the inside of the bowl edge.
For more info on how a toilet works = http://www.aplumbers.com/residential/toilet
solution 1
2. flush, the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2 it could be the water levels to high.
(solution 2)
2. if the waters flowing over the long tube in the center and down then the water level is too high 3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing. 4. adjust water level . 5. lift the flapper to allow a little water out til fill valve kicks on then release handle til valve stops . 6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 14, 2010 | Kohler Acorn Lift-Knob Flush Actuator...
The water level in tank is low. How do you adjust?
There's no certain way for me to know which fill valve you have in there, but locate the float. This floats on the water level and turns off the water when the tank is full. There's probably a screw on the float arm that lets you adjust the float up and down, adjusting the full water level. You may be able to loosen a collar on the bottom of the fill assembly and slide the whole thing up and down (make sure you turn off the water valve when you do this because the whole thing can pull apart), or you may be able to simply turn the entire fill assembly which will raise and lower it if it's built that way. Make sure the new water level doesn't go above the level of the refill tube or the water will go down the tube and the valve will never turn off.
Jul 12, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
When the tank refills, the amount of water that is
The fill level can be adjusted by either lowering the filler valve column or bending the filler arm down. The adjustment method is dependent on the type of filler valve. Be cautious not to allow the fill level to go above the designated fill line.
Jun 21, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Seth Thomas St. Thomas Creations Daytona Dual Flush Elongated Toilet Bowl - 6145.223.02 Logo
117 people viewed this question
Top Seth Thomas Home Experts
Austin
UsedClockPartsdotCom...
William Smith
William Smith
Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
