Question about Kidde Carbon Monoxide (KNCOBB) and Smoke Alarm (0916) Value Pack
How to fix detector
Carbon monoxide detector beeps once every 30 seconds, tried new batteries and it still does it. Tried blowing out dust and it still does it.
    Sniper:
  • 54 Answers
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
Posted on Jun 10, 2010
SOURCE:
Co detector garrison 46.0019.0 of may 2011 Rings continuously until batterynew removed
Junai, Try to vacuum/blow dust out of detector, if this does not work detector faulty and will need replaced. Most detectors have a label stating replacement date or expiry. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kidde.com/home-safety/en/us/co-safety/about-carbon-monoxide-alarms
Looking for Answers about Garrison Garrison Plug in Carbon Monoxide Alarm
Why is my Carbon Monoxide Detector Beeping with pictures
Jun 19, 2016 | Alert Home Security
My camper has been in storage for 2 months. The carbon monoxide detector beeps every 30 seconds. I pushed the reset button and it does no longer beep. Is it still safe to use this detector?
Dale, My alarms beep like that to warn me of batteries needing replaced. What I do is hit the test button and ensure it sounds. I would still replace the battery(ies) and retest when you do.
Mar 07, 2015 | Kidde Carbon Monoxide Alarm Model Kncobb
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
Beeps every 30 seconds. New batteries and still beeps every 30 seconds
If the replacement battery you used was fresh out of a package and not a recycled battery, the unit may simply need cleaning. As they do become clogged with dust and lint.
To accomplish this, you will need a can of compressed air that has a straw nozzle (like you clean your computer with). Remove the newly installed battery and us the battery compartment as a portal to blow air (using the straw nozzle) into the detector. Don't just blow in one place, shift the nozzle around as much as possible. If you can get the cover off, so much the better. Then blow out the sensing vents on the front. Wait a few minutes and reinstall the battery. If it continues to chirp, press the reset button.
This should solve your problem. Remember to clean any and all smoke or carbon monoxide detectors at least every 6 months.
Mar 03, 2011 | Kidde Carbon Monoxide Alarm
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Kidde Carbon Monoxide (KNCOBB) and Smoke Alarm (0916) Value Pack Logo
1,709 people viewed this question
Top Kidde Home Experts
 Henri P
Henri P
Ray Haas
Level 1 Expert
Are you a Kidde Home Expert? Answer questions, earn points and help others
