Question about EliteGroup 661FX-M Motherboard
How do you flash bios for Elitegroup 661fxm - EliteGroup 661FX-M Motherboard
    President:
  • 2,351 Answers
Its suggested to follow the instructions listed on ECS web site. Open the link provided; http://www.ecsusa.com/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=661FX-M
There are three versions for this MB. Choose the matching rev for you're MB.
http://www.ecsusa.com/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=9&detailid=392#Download-2
Cheers'
Mike
Posted on Jun 01, 2010
By mistake i am instoling wrong bios so my motherboard goes with no boot,no display is it any way to re flash the bios
Yes you could FLASH ur BiOS by just jumpering the PiNS!
Its in ur owners manual, if haven't got the manual, download it in the net... just type in any search engine ur mobo's type!
Nov 20, 2010 | EliteGroup ECS P4M800-M7...
Reprogramar bios
Aquí te envio el enlace para que descargues el Bios hay varias versiones, controladores y manuales. Te recomiendo que seas cuidadoso con el Bios ya que si descargas este y lo aplicas incorrectamente sucede lo que se llama flashear el Bios y tu procesador quedaria inservible. si lo has hecho antes y te sientes confidente adelante.
si esto te funciona no olvides calificarme grcs
Here is the link to the page where you can download the Bios (there is a few versions), drivers and manuals. I recommend you to be careful because if you apply this changes to the Bios incorrectly can happen what is called Bios flash and that will ruin your processor. if you have done it before and you are confident then use the link.
if it works for you, don't forget to rate me
thx
May 26, 2010 | EliteGroup ECS G733 Notebook
After setting the bios for formatting my ecs p4vmm2 v5.0A hangs up what could be the problem and solution for this problem pls help me...
I had that motherboard, wasn't happy with it at all.
But you can flash the BIOS if you want . Make sure you download the correct BIOS version. There are like 10 versions for P4VMM2. I chose the wrong one last time my system didn't boot. I threw the motherboard away, purchased an Intel Motherboard.
I'm not a ECS fan at all. Use AMI flash utility , flash the BIOS under Windows.
May 08, 2010 | EliteGroup P4VMM2 Motherboard
Flashed the BIOS on this Board with the wrong ROM File... I tried AMI Boot Recovery Thru Floppy, USB and CD... still wont read any of them... Any Suggestions??
Download the correct ROM from the manufacturer and re-flash.... Unless you know someone with the same motherboard, or can go into the shop that you bought the board from, then you can copy their rom and flash it to your BIOS. I had that happen to me a few times too...Next time copy the BIOS before flashing over it.
PLEASE RATE THIS ADVICE WITH A FEW THUMBS UP!!!
Apr 23, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
My old bios date 07 14 05 16:02:19 need new
you can download it from the web but be care full when you will flash your bios.
Apr 06, 2010 | EliteGroup 536 Notebook
Can not start scooter with break and switch
reset bios and cmos or just do a bios flash ask someone with exp. to help you or you going to loose youre board if you mess up bios flush
Mar 21, 2010 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
AMIBIOS ROM Size: 1024 KB BIOS Build Date: Jul 07 2008 Motherboard Manufacturer Code Detected: 1131 - ELITGROUP Please Consults ELITGROUP for support AMIBIOS Build Tag: 2E3C3S1 AMIBIOS Project ID: 2E3C3S1...
I am guessing that you want a BIOS update for your EliteGroup GF7050VT-M5 Ver 1.0 motherboard, am I right? There is one update, newer than yours: (read the warning about updating [flashing] your BIOS)
If you wanted something else, it is probably there too!
Dec 31, 2009 | Computers & Internet
BIOS won't save changes after changing CPU.
you may need to "flash or upgrade the bios.
Dec 27, 2009 | EliteGroup 848P-A Motherboard
Dear sirs, i put wrong parameters in bios. so
99% of all bios don't need to be flashed or updated. Unless you have a specific problem with your bios and you go into the manufacturer's website and can read about the bios updates and see your problem as one of the ones that the bios update fix, don't update your bios. It's not going to make your computer run any better, it's not going to cure all the problems you have. About half the time it just messes up your computer or can ruin it. A lot of motherboard manufacturers have come up with Windows based programs to flash the bios but if they fail then you have to go back to the old method and they usually require having a floppy disk which most computers don't come with anymore. If you're one of those people that want to play around with your computer and do a little experimenting you're must better off to go format your harddrive, wipe it clean and start all over. Then you can go find all your new driver updates, software updates, find all the files you just deleted off your computer cause you forgot to backup before you formatted it. It's a lot more fun than flashing and updating your bios because your computer will still work when you get done. Sorry dude if the pin reset doesn't work the only option is possibly putting a new bios chip on the motherboard but I haven't seen one of those in years. Not sure they even still make them detachable and you'd have to find a motherboard to get one off of.
Dec 05, 2009 | EliteGroup L7S7A2 Motherboard
Bios error of type ffff plis assist to trouble shoot.
download the EXACT bios for that motherboard and flash the bios
Oct 05, 2009 | EliteGroup Computers & Internet
EliteGroup 661FX-M Motherboard Logo
120 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
