Question about Epson Stylus NX400 InkJet Printer
How to change ink cartridge? When scanner lid is lifted ink cartridges do not slide over to be removed.
    Scholar:
  • 117 Answers
If the printer still thinks the cartridges have some ink in them (ink light blinking, but NOT SOLID RED), it won't move the carridges into place- this only happens when they are completely empty. if you want to change them MANIUALLY you will have to look for "changing ink" in your manual- usually, but not alwyas done by holding down the INK button for 3 seconds, but like I said- check the manual, and if you don';t have it, downlaod from EPson website
Posted on Jun 01, 2010
HOW TO CHANGE CATRIDGE
Purchase an ink cartridge made specifically for your printerTurn on your printer and raise the lid or press the cartridge changing button Wait for the cartridge carrier to slide out. Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Close printer cover.If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
Sep 06, 2011 | Computers & Internet
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
How do i replace my ink cartages
Removing a used print cartridge:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the lever to raise the cartridge lid.
  4. Remove the used print cartridge.
To install a new cartridge, remove the sticker from the back and bottom of cartridge. Insert the new cartridge in the slot. Close the lid. Lift the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
Source: Lexmark X2400 Series User's Guide
May 18, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do I change ink cartridges onEpson Stylus SX425W printer. Apart from lifting the scanner I cant see any buttons to press and the present cartridges wont move along to enable me to eject the black one.
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed.
Then, "unlock" the ink-cartridge from its socket, and gently remove it.
Replace it.
Then, "lock" the ink-cartridge into place, and close the lid.
Print a test-page.
Apr 11, 2011 | Epson Office Equipment & Supplies
How to replace ink cartridge
1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Dec 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
How do I change the ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The print cartridge carrier moves to the center and stops at the loading position. Grasp the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges and install the new ones. Snap the lids closed and lower the scanner unit to close.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Hope this helps. Thanks.
Nov 22, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1150 - how do I change ink cartridge
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Thanks.
Nov 18, 2010 | Lexmark C533DN InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Forgot how to change ink
Lift the lid that covers the print-mechanism.
In a few seconds, the cartridges will slide to a place where you can easily remove them, and insert a replacement cartridge.
Close the lid.
Jul 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus NX400 InkJet Printer Logo
152 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
