I am having trouble using the scanner "canoscan12640UF with Vista even tho I have run the disk on my computer, I used to have Microsoft '98 & it worked on that.
    Sergeant:
    Champion:
  • 293 Answers
Download the driver for vista
Posted on Apr 08, 2008
I downloaded the drivers to my vista computer but keep getting an "unable to select Twain Source error".
The drivers for your Canon CanoScan 4200F Flatbed Scanner available are for Windows 7 64bit, Windows Vista 64bit, Windows ME and Windows 98. Is your Windows Vista a 64bit version? You might want to upgrade your Windows Vista from 32bit to 64bit. Always remember, the softwares and drivers are limited to manufacturer's releases.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 21, 2011 | Canon CanoScan 4200F Flatbed Scanner
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Want to install umax astra 3400, using windows vista, won't recognize, what do I need to do?
There's only one way I've found to run this scanner on a computer with Vista, but its cheating since you really don't use Vista. Look at Knoppix 6.2 (www.knoppix.org). It has a scanner app (Xsane) that will run the Astra 3400 (using Plustek USB driver). The catch is you have to boot from the Knoppix CD (or DVD) which lets you run LINUX in your RAM, but won't mess with Vista on the hard drive. Save your scanned work to USB flash memory when done, then boot back to Vista and do whatever with those saved files. You have the option of various file types and even multipage PDFs.
Nov 16, 2009 | Umax Astra 3400 Flatbed Scanner
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
Lost setup disk 4 my Canoscan LiDE 100
This is Canon Support, and the support page for the CanoScan LiDE 100,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=17104#DownloadDetailAct
On this page you'll see the file downloads, for the User On-Screen Manual. Both for Windows or MAC.
There is also a Quick Start Guide, that is in PDF file format that you can download.
At the top you'll see the heading -> Drivers/ Software Selection.
Under that it states, "Please select your Operating System to view available drivers and software"
You just click on the blue down arrow to the right of the box, then left-click right on the Operating System you're using.
Not knowing what Operating System you're using, I chose Windows XP as an example:
After you click on your Operating System, the drivers immediately appear, (At least they did with Win XP)
Under the Drivers heading, and the sub-heading, File Name and Description,
it lists -> LiDE Scanner Driver Ver 14.0.1 (Windows Vista/Vista 64/XP/2000), then has -> smwin131en.exe <- in Red.
This is what you click on.
You'll be taken to another page, where you click on -> I agree
From there you should get a small pop-up window. It may be a 'Squawk Box' from Microsoft. "Warning this software, ya-da, ya-da"
It's okay. Click on Run. Then click on Run again.
This is if it's going to be used on the computer you're using to operate the scanner on.
If not, click on Save.
If you don't have your downloads saved to go to your My Documents folder, it will go to your desktop screen. Remember, or write down the file name, so that you can find it later, then click on Save.
Burn this file to CD disk. After you install it into the computer you want, you may have to go to My Computer, (Start>My Computer),
and double-click on your CD/DVD drive letter,(Example: (D:)
May 09, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Install software for HP Officejet 6210
software for HP Officejet 6210. please choose your correct operating system.
» Microsoft Windows Vista s.gif » Microsoft Windows Vista (64-bit) s.gif » Microsoft Windows XP s.gif » Microsoft Windows XP x64 s.gif » Microsoft Windows 2000 s.gif s.gif » Microsoft Windows ME s.gif » Microsoft Windows 98 s.gif » Mac OS X s.gif » Mac OS 9 s.gif » Linux
I recomment you to download HP Full Feature Software. <-- If you have trouble finding it, you may contact me.
Jul 10, 2008 | HP Officejet 4110 All-In-One InkJet...
I have just purchased a samsung printer, but it says on the user sheet "according to the policy Microsoft does not support Windows 98 USB Driver and PS Driver of Windows ME/NT. Does that mean I can't...
no, it means if your windows version is win 98, then you need a separate driver for the printer to work with usb. You can use the printer for other versions of windows like win XP and win 2000 or maybe even windows Vista
Jul 02, 2008 | Samsung Office Equipment & Supplies
No VISTA DRIVER!!!!????
Load the XP drivers and run it in compatibility mode. Or right click on the exe files after unzip and mark in compatibility mode xp. Works fine!!
Dec 16, 2007 | Canon CanoScan N656U Flatbed Scanner
How to set up and use
What is your computer's operating system? » Microsoft Windows Vista » Microsoft Windows Vista (64-bit) » Microsoft Windows XP » Microsoft Windows 2000 » Microsoft Windows ME » Microsoft Windows 98 » Microsoft Windows 95 » Microsoft Windows NT 4.0
Oct 06, 2007 | HP ScanJet 2200C Flatbed Scanner
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
