Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Pilot lites up but heater does not work even having knob on high
Pilot lites up but the burners don't come on even if the knobs are on high. This is a manual knob.
    Problem Solver:
  • 15 Answers
If the gas valve isnt opening, it will not allow gas ito the burner trays. Gas valve could be bad.
Posted on Aug 22, 2010
Why does burners and pilot forced off after burners are engaged
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Jan 18, 2016 | Procom Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
I have. A 40 gal. 40,0000 btu natural gas , how do u lite the pilot light
Access is at the bottom of the water heater. There is a little cover you will have to take off. Look for the gas valve. (its where the gas will come in to the water heater) Follow the two lines that come off he bottom of the valve. They will lead you to the burner (big line) and the pilot(smaller line). The pilot is what you are looking for.
1. locate the pilot (it will be 8" or so in to the water heater)(right next to the burner)
2. Turn knob on top of gas valve to "pilot"
3. Push down the knob on top of the valve that you just turned to "pilot" or there may be a lever right next to the knob on some models
4.with a long fireplace match or bar b que lighter, while holding the knob down, reach your lighter to the pilot assembly. you may smell a little gas.
5. The pilot will light, do not let go of the knob for 30-45 seconds
6. After a few seconds let go of the knob and turn it to "on"
7. Check your thermostat make sure it is not on "vacation" and turn it up to see if the burner ignites.
You are ready for hot water if all works. Hope this helps you, have a good day.
Apr 18, 2011 | General Electric Water Heaters
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
I HAVE MODEL GP30 WALL HEATER. I CAN LITE PILOT BUT WHEN I TURN CONTROL KNOB UP PILOT GOES OUT AND DOES NOT LITE HEATER
The thermocoupler is bad.Replace it,or if you can adjust it to where the thermocoupler is in the pilot flame.You know you have to hold the knob down for about 30 seconds or a minute,don`t you?If the flame will not touch the thermocoupler,it will not stay lit.You can cut a piece of copper tubing,or steel tubing to slidde over the old thermocoupler to make contact with the pilot flame,and it will work,if the thermocoupler is not in to bad of shape.
Oct 17, 2009 | Heating & Cooling
Can't get the pilot to stay lite after I turn the knob to the "on
sounds like a thermocouple its a metal proble looking thing nex to the pilot light with a small copper tube attached to it that goes back to the burner control.
Aug 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Burner will not ignite as pilot light goes out when knob is released
Are you holding the knob for 30 or more seconds,If so,Clean or replace the thermocouple/Flame sensor.
May 29, 2009 | Endless Summer (GA200209) Stainless Steel...
I have no hot water, the pilot light is on help!
First try turning the knob all the way to "pilot" then turn it all the way to its hottest setting.
It sounds like the thermostat/sensor is stuck. This may jar it into working again.
Also look for any leakage or water around the burner.
You will probably have to replace the gas valve in the near future.
Also try tapping the side of the gas valve.
Jan 23, 2009 | General Electric GE SmartWater Household...
Canot locate remote swich or instructions how to get water heater pliot lit on 1984 itasca motorhome
look for the gas valve and on the top of it there should be a valve that has either off, pilot, or on. Turn it to pilot and depress the knob. At the same time follow the small tube that comes of the valve and at the end of it is the pilot burner. Hold a match to the pilot burner and when it lites keep on holding the knob down for about 20 seconds. If you can release the valve and the pilot stays lite then you can turn the knob on the gas valve to on.
Dec 21, 2008 | Heating & Cooling
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
124 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
