Question about Amana NDG2335AW Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Amana NDG2335AW Gas Dryer runs but doesn't heat up, it's three years old. /vents are not clogged. No heat from the back at all.
    Problem Solver:
  • 13 Answers
If your dryer has an access panel on the bottom see if you can get it opened.if you can turn on the dryer ,you should hear a click and after@ 30 seconds the igniter should start to glow.if it dose not your igniter could be broken.shut off the dryer,pull the plug and check it for a crack.If it dose glow and it goes out but don't get a flame you could need a flame sensor or a set of coils for the gas valve
Posted on Jun 01, 2010
  • 10,319 Answers
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
Posted on May 31, 2010
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Dryer comes on,cycles according to timer,but not heating,sometimeshad gas smell
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 20, 2010 | Amana NDG2335AW Gas Dryer
No heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Amana NDG2335AW Gas Dryer
Dry will not blow heat
Check the entire exhaust vent tubing before buying anything for this dryer to repair.. Most dryers only need a good cleaning to get the heat back running correctly. A moister sensor is working if the lint build up is more than just dust in the vents tubes. Any build up the sensor detects and keeps the heat off. Sometrime you will get heat for awhile although it will shut the burner down quit soon
Jun 09, 2010 | Amana NDG2335AW Gas Dryer
Amana NEW7200TW (1 year old) runs, but stopped heating.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 30, 2009 | Amana NED7200TW Electric Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Amana NDG2335AW Gas Dryer Logo
323 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
