Question about Behringer Bdi21 Bass V Tone Modeling Pre Amplifier Stomp Box
How to connect it to computer mic input
How do i connect behringer bdi21 to computer mic input so i can record it?
    President:
  • 1,138 Answers
Instead of using the mic input on your soundcard try using the auxiliary input. You will need a cord that converts from 1/4" mono to 1/8" stereo. That cord goes from out on your pedal to aux in on your computer. Use whatever you need to go to the input of the pedal.
Posted on Jun 03, 2010
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the mic XLR plug whilst the amp was still turned on.
You should be able to unplug a mic from the xlr input with the unit on with no problem.
I beleive the problem is that the xlr input jack has one or more legs broken off the board. If you dsassemble the board and resolder the three legs to the board you'll probably fix the problem.
Dec 01, 2015 | Behringer Music
I got behringer 802 audio mixer and a mic..what else do i need to start singing..
Please verify if your computer has a sound card. You will need a provision on your computer for audio input. Let me know.
Dec 26, 2014 | Behringer XENYX 802 Mixer
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
Connect xenyx 2442fx to computer
If you want to record in stereo, the quick and dirty way is to get a 1/4 inch stereo to 1/8 inch plug cable and go frrom the headphone output jack. (Use a Wye connector if you need to listen on the phones)
All the other outs are TRS and XLR balanced and the computer audio (mic) inputs are unbalanced. You would need special cables to connect those.
Feb 08, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Behringer Bdi21 Bass V Tone Modeling Pre Amplifier Stomp Box Logo
150 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
