During a white load the machine stops at 38 minutes and gives a LF error on the screen. I try to restart and it makes funny noises but no water comes out; sometimes the time cycles down to 28 or so minutes but stops with another LF error. If I cancel out the cycle and put it on rinse & spin it finishes the load. It so far appears to only happen when running on the "whitest whites" cycle. Any solution for this??
Lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
I have one of these washers and I have found that if my hot water is low exm. someone jsut took a shower, then I get this code because the water is not hot enought
