Question about Nelson Sprinkler: Traveling Tractor
Help, our nelson sprinkler doesn't spin like what it supposed to
Help, our nelson sprinkler doesn't spin, if it spin it is very slow even when you put it in the highest sittings. It wasn't like that when we first got it 3 years ago... thanks
  • 218 Answers
SOURCE: Nelson Tractor Sprinkler goes slow and intermittently.
I dont know of a repair kit but it sounds like the motor needs replacing..and you can find the parts online at www.lrnelsoncorp.stores.yahoo.com i hope this will help
Posted on Jul 08, 2009
carlsbiz
  • 1124 Answers
SOURCE: Who do I contact to get parts for my Nelson
You should be able to find parts here
---> http://www.sprinklerwarehouse.com/
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
  • 76 Answers
SOURCE: Nelson traveling sprinkler broken plastic part
If some part of your sprinkler is broken you should replace the whole sprinkler .
Posted on Jul 16, 2009
SOURCE: my nelson travling sprinkler wont move, just cicks
I* am certainly not an expert repair technition but I do own a Nelson traction sprinkler and did the following to mine.
I've not checked but I doubt seriously that the transmission is only ten dollars and I doubt if you can spray oil into the axles that it will last very long. The transmission is plastic and nylon and surely gets brittle over time so do not go nuts forcing it. The transmission is held to the casting with hexhead slotted screws. I did not even try to loosen them with a screwdriver as you will only strip the slots-use a socket wrench-they are surely stuck. With the bolts out the transmission is easy to remove. I could open the case about 1/4 inch before it would not go any further. I think you need to remove the part onto which the T shaped piece that the arms attach to. My sprinkler is quite old and I did not want to disassemble too much so with a clean dull old knife it was easy to apply marine waterproof grease to the gears and the axels. I then, reinstalled the transmission and hand turned the arms in both high and low gear to distribute the grease.
I works fine now with water and should last for another 20 years.
Posted on Dec 08, 2009
SOURCE: Nelson rain train traveling sprinkler 1865 wheels
My rain train just locked up - wheels will not turn. How do I fix this?
Posted on Jun 28, 2011
Nelson Sprinkler Rain Train Traveling Sprinkler will only go backwards , i have the arms going in the right direction...please help
If it's going backwards, and assuming you didn't take it apart and put it together wrong, then the arms aren't going in the right direction. Looking down from the top, my unit should be moving clockwise if it's set up correctly. In any case, switch it so the water pushes the arms in the other direction. the transmission is pretty straightforward - if it's going in the wrong direction then the arms are spinning in the wrong direction.
Aug 02, 2011 | Nelson Sprinkler: Traveling Tractor
I have a Nelson Pulsating sprinkler and can't figure out how to make it go all the way around
See if the stop that makes the sprinkler reverse by hitting the adjusting rings can be lifted up so that it doesn't hit the adjusting rings.
Gary
Jul 22, 2011 | Nelson Garden
Need replacement gears for Nelson sprinkler. Can you help
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 16, 2011 | Nelson LR Rain Train Traveling Sprinkler...
I have a couple of Nelson tractors. Is water supposed to come out of the little holes on the bottom of the gear housing?
heatman101
Aug 12, 2010 | Nelson Sprinkler: Traveling Tractor
Need parts for traveling tractor where can I get them?
Have you tried their website? These sprinklers are relatively expensive units as I remember. Well made and well worth fixing. Usually nylon gears with stainless steel shafts. Parts should be available through Nelson. Google: Nelson Traveling Sprinklers and see what sites pop up. If this has been helpful, please rate it accordingly. Good luck.
Jul 15, 2009 | Nelson Sprinkler: Traveling Tractor
Jul 07, 2009 | Nelson Sprinkler: Traveling Tractor
Nelson Sprinkler:  Traveling Tractor Logo
97 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
