Question about Home
I have a designa ds3000 electric shower, the power light does not light upand the water is cold and will not heat.....please help
4 Suggested Answers
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
  • 659 Answers
SOURCE: Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Posted on Mar 21, 2009
Triton 300si wireless shower problem - Shower motor is working but the low presure sign is flashing but all other water pressure is normal. Water was coming out but going hot and cold but has now stopped...
check inlet water first for consistency, if flow is fine and pump is working correctly, then check non-return valve on your pump outlet.
if these check correctly, check electrical side, if flow to heating element is constant, if that is interrupted, i am afraid that motherboard on your unit may be faulty,
you have then only two choices, dismantle the unit and check all wiring and component or get unit to repair centre or call plumber... or eventually replace unit by yourself.
please be aware that mendling in electrical circuit is dangerous! fully disconnect from power before you remove the covers!!
please be aware that before you attempt to repair electrical or plumbing gear you need to cut off power or water supply to the unit in full, they do not mix very well... :-)
Jul 29, 2010 | Home
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Does not put out enought heat
Hi this is tech crazy
the solution and reason to the problem mentioned by you is as follows:
As cold water comes in, it remains at the bottom of the tank because it is denser than hot water. If you use the hot water faster than the heating elements can heat the incoming cold water, and if you consume all of the hot water that the tank holds, you run out of hot water in the middle of your shower. If this seems to happen too often, it could mean that the bottom heating element in an electric water heater has burned out or that your water heater is too small for your house. Or it could mean that you are taking really, really long showers.
Hope this helps u a lot
Please do rate me on the above said solution
Feb 04, 2009 | Empire RH35 Mid-Size Heater
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
Home Logo
255 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
