Question about Intel Dialogic D 240PCI-T1 (99-2241-011) Modem
D/240JCT won't connect to layer one
The T1 is configured as a PRI 23b + d
Switch Type = NI2
Encoding = B8ZS, ESF ( Extended Super frame(standard settings))
PCM encoding = ULaw
The card passes all diagnostics but fails to initialize (see capture info below)
C:\iWB35\core\gateways\vru>vru /Nivrgate001 /d3 /t3000 dtiB1T1 c:\sounds "" yes 7
vru
Version 4.2.1 (Build 2092 Unicode Wealthview Platform Release)
Copyright (C) 1985-2008 Fincentric Corporation
Voice Gateway (Device dtiB1T1)
13:22:21:837 VRU (null): ProcessChannelName: DTI device [dtiB1T1]. Voice processing device [dxxxB1C1]
13:22:21:853 VRU dxxxB1C1: OpenISDN: Attempting open of digital device [dtiB1T1]
13:22:21:884 VRU dxxxB1C1: Error opening device dtiB1: errno = 2
Interactive Voice Response (IVR) Gateway Terminating
Diagnostic trace output written to C:\DOCUME~1\QA\LOCALS~1\Temp\vru_0031.log
Use NT EventViewer to see Application EventLog for additional information.
mdsaeed67
  • 849 Answers
SOURCE: sis651 no sound
you have not installed the soud drivers, it runs on modem sound, try to install the sound card or built in sound drivers.
Posted on Oct 21, 2008
  • 254 Answers
SOURCE: sis651
have the sounds been enabled in the bios. ?
Did you run the motherboard drivers disk on your pc ?
HOPE THIS HELPED
Posted on Jan 07, 2009
florin_decad
  • 203 Answers
SOURCE: VIA/S3G UniChrome Pro IGP drivers and realtek ac97 driver problem
http://global.msi.com.tw/index.php?func=downloadindex
go there .
Posted on Feb 05, 2009
  • 2567 Answers
SOURCE: SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
Posted on May 15, 2009
  • 87 Answers
SOURCE: I was lost my motherboard drivers.
go to the manufacturers website and download the drive for your mobo, if your internet doesnt work you may have to download them on another computer burn them to disc
Posted on Mar 08, 2010
Where is the Caller ID for Outbound calls programmed?
Have you resolved this yet? If your CO connection is analog, it's done by your telco. If you have a PRI (T1), then it's in your system's configuration.
Jun 26, 2014 | Nortel Lands Phones
Incoming caller ID on a Option 11 Meridian - can you recieve the incoming caller ID?
I believe so. You will need to know the construction of the caller ID string sent by the telco through PRI and then the ICS needs to be programmed to display the portion(s) of the string desired by the customer.
Dec 19, 2012 | Nortel Meridian Option 11 PRI/T1, NTAK09...
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
Lucent Magix Avaya
Magix is discontinued product. Suggesting upgrading to IPOffice.
Then you will be able to see if carrier is the real problem.
Mar 17, 2009 | Lucent Lands Phones
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Speed on vsx 7000 appears stuck at 64k
configure Bri Board as trunk in MSN config.  Create isdn trunk and add bri port to this trunk. Create routing to this trunk for VC number.
Dec 08, 2008 | Polycom VSX 7000 Video Conference
New Drive Missing Hive
put the dvd writer in slave position with the help of jumper near the data cable insertion,
May 15, 2008 | Computers & Internet
Brand new Super Multi DVD Rewriter model GSA - H55N
Are you copying commercial DVDs? What you are seeing is indicative of Macrovision encoding...accordianman
Feb 28, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Intel Dialogic D 240PCI-T1 (99-2241-011) Modem Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
