Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Heated panel The face of the panel between the freezer and refrigerator is hot.
    Novelist:
  • 77 Answers
Turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Posted on Jun 02, 2010
Temp in the freezer and refrigerator not as cold as they should be. COntrol on the coldest.
There are two sets of coils for cooling appliances like refrigerators, they are called the evaporator3 and condenser1 coils. Overly simplified, the two coils are filled with gas and liquid respectively, and are parts of a complex "circuit" that has a compressor4 and expansion valve2 that perform the work. The gas filled evaporator coil is located in the space to be cooled, and performs the task by absorbing heat from that space. It is usually protected from damage and out of view inside the freezer section. The "heated" gas is compressed by the compressor, where it is further heated (hot to the touch) by the compression process. The heated compressed gas and liquid is passed through the condenser coil that is located away from the cooled space. This condenser coil is where some of the heat in the liquid is released to the ambient air. The cooled liquid is then drawn through the expansion valve by the suction of the compressor, where the liquid immediately boils off to a gas. This causes the temperature of the gas to drop significantly (well below freezing) in the evaporator coil. The process repeats until the thermostat in the space is satisfied. Because the condenser coil is exposed to the ambient air on the refrigerator, it requires regular cleaning. There are a few locations that the condenser coil may be found:
  • Older refrigerators have the coil (a grid-like structure often painted black) mounted on the rear of the refrigerator.
  • Newer refrigerators often locate the condenser coil at the bottom. It is likely that a fan (that may or may not be readily visible) will be directed at the coil to assist with heat dissipation. Use a flashlight to assist locating the coil and fan if needed. The coil will be accessible from one of two places:
    1. Toe space panel. Remove the panel at the bottom of the front of the refrigerator and carefully slide the condensate tray out (if present, the condensate tray may contain water). A visual inspection upward into this space may reveal a flat condenser coil when located here.
    2. Rear access panel. If not found behind the toe space, the refrigerator will have to be slid away from the wall further to work from behind. Disconnect water supply lines if too short to allow enough room to work. Remove the fasteners that holds an access panel in position. The condenser coil may be flat, but will likely be cylindrical in shape when located here.
Feb 03, 2015 | Refrigerators
Very hot between doors
Warm in that area is normal because heated Freon travels around the door frame on most refrigerators because it prevents sweating between the cold inside of refrigerator and the cold air inside of freezer The problem of getting hot may indicate a defective condenser fan or the air below refrigerator is obstructed by dust. Check those two things and if you have any question I will be here to answer them for you. If helpful please rate this solution, Thanks Sea Breeze
Feb 29, 2012 | Admiral 26 cu. ft. Side-By-Side...
Water is occasional on the floor below the lower left hand corner of the freezer on my side by side kenmore freezer and refrigerator as you face the unit
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 05, 2011 | Kenmore Refrigerators
Freezer still working. Refrigerator not cooling. Hot to top on inside of left hand door as you face refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Kenmore Elite Trio 7855 (25 cu. ft.)...
The freezer is freezing up behind the panel causing the frig side to become hot
check with dealer or company regarding frig in back panel.side always become hot due to inbuilt condenser.place in such a way that front and both the side facing to open area.do not face to wall either of the side.back panel towards the wall will do
Nov 17, 2010 | GE Refrigerators
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
