Question about Kenmore Oasis HE 27087
Machine reads "Ld" and will not run any water to the washer.
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the Cabinet....
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)(*&
Posted on Sep 27, 2010
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
Had ld reading on screen which is nicked or clogged hose repairman came and replaced pump. i washed 1 rug and it was fine, went to wash another load and got the same ld reading as before, called and was...
You should not wash rugs in this machine. The Long Drain is caused by rubber backing from the rugs flaking off and jamming the pressure tubing. The control cannot detect if water is leaving the machine ok. Take that tubing off the control and blow it out. This washer uses a small amount of water which is continually dumped over the clothes. The pump is strong on these washers. The problem is gonna be sediment in the base of the tub clogging that tubing.
Repair photos and manual are HERE
Feb 03, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is indicating a "ld" problem. I have readjusted the load and restarted the machine but it continues to stop and the "ld" code keeps coming on. I have a very small load in the machine so I know...
Hello, the "Ld" error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
  • Is the drain hose kinked or clogged?
  • Check the drain pump for clogs. Is it running?
  • Is the drain hose height greater than 96 inches?
  • Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
  • Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
  • Thanks
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is diplaying Ld and won't restart
Ld stands for long drain.
Here is what the manufacture says about that error, my comments will follow.
LONG DRAIN If the drain time exceeds eight minutes, Ld will be displayed, the water valves will turn off, and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be cleared and the machine will turn off after a maximum of eight minutes. Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the drain pump filter for foreign objects, and also make sure the hose from the tub to the pump is not plugged or kinked.
4. Check the electrical connections at the pump and make sure the pump is running.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments -----> This error is usually due to something getting stuck in the drain pump or drain hose, typically after washing a rug with a rubber backing that has come off or small articles like baby socks that were not put into a garment bag prior to washing.
To clean out the pump the machine would need disassembled and is best done by a service professional unless you are up for a good challenge.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We are getting ld error code, also machine motor dosen't seem to be running when we try another cycle
Ld flashes when the water level does not change after the drain
pump is on.
➔ Is the drain hose clogged?
➔ Is the drain hose height greater than 96′?
➔ Is the pump running?
TECH SHEET
Feb 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite calypso washer
"Ld" indicates Long Drain: Ld flashes when the water level does not change after the drain pump is on.
depends on the following factors:
1-> the drain pipe could be longer than 8 feet
2-> the drain hose could clogged or kinked
3-> the pressure hose connection from the tub to the machine motor control could be pinched or plugged?
4-> and finally the pump might not be running well.
If you need any sort of help with the disassembling of machine tell me the exact model number and i can provide with some internal diagrams.Good luck with the machine.Please do rate my solution, also do post comments in case of further doubts.
Jan 24, 2009 | Kenmore 20172 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27087 Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
