Question about Canon imageRUNNER 2000 Copier
E004 yesterday , it showed E000 and I tried to operate again ' its okay but in this morning , it shows E004 I can't do anything with this error
  • 1,219 Answers
This is fixing error, probably bad thermistor. You should check the termistors, lamp, termoswitch.
But first try to clear the error in service mode
MENU i #
Clear
Err
OK
Turn off/on
But you have temperature issue in fixing section
Posted on Jun 02, 2010
How to solve canon np7161 error code 104
To clear E000 through E004, operate as follows:
1) Select '412' (clear E000-E004) in service mode.
• The copier's control panel indicates the respective error code.
2) Press the Start key.
3) The copier will automatically turn off, clearing the error.
E004
• The triac has a short circuit.
• The DC controller PCB is faulty.
Fixing heater (H1)
=Execute service mode '412' (error clear) to clear E004.
Turn off/Turn on the power switch. Does the fixing heater turn on?
Triac
=Check/Replace the power supply PCB
DC controller PCB=Check the wiring from the power supply PCB to the DC controller PCB
The fixing heater fails to turn on.
Thermal switch (TSW1
Turn off the power switch, and remove the fixing assembly. Set the meter range to
"Wx1." Does the meter index swing when the probes are connected across both terminals of the thermal switch
Fixing heater (H1)
Turn off the power switch, and remove the fixing assembly. Is there continuity when probes are connected across both terminals of the fixing heater
DC controller PCB
Set the meter range to 30 VDC, and connect the probes to J106-21 (+) and J105-4 (-) on
the DC controller PCB. Is the resistance about 5 V
Using Service Mode
1) Press the User Mode key.
2) Press '2' and '8' of the keypad at the same time. (Hold them down for 0.5 sec or more.)
3) Press the User Mode key once again.
Feb 27, 2018 | Canon Office Equipment & Supplies
No sound
TV was working okay yesterday The screen is showing no signal when I turned it on this morning, I check the cable hookup
Nov 19, 2013 | Olevia LT42HVi 42 in. LCD Television
Canon copier error code E000 and i can't clear it
The errors E000 to E004 refer to a fuser problem. There may be a problem or it may just be a random error which can be reset in the service mode.
I am terribly sorry but as i am Canon engineer i am forbidden to tell you how to activate the service mode. I am sure you can find it somewhere on the net.
Good luck.
Jul 23, 2011 | Canon imageRUNNER 2000 Copier
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
#7 PRINTER > #4 PRINTER RESET > YES = (*).
sonsunny
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
D861 E000 show up.. unplugged and reconnected still shows E000 Cannon Product
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon ImageClass D861 Printer
Couldn't register service provider. Display shows ''LTD. SERVICE''
Its purely network problem. Dont try again and again with the same solutions. Switch off the mobile for some time, remove battery, and sim card, and put them again after some time and switch it on. In samsung, while switching on, it will show the service providers name in the start up screen. if it shows, then it should work. If it doesnt work, some problem with the sim card. try to replace it. or otherwise general operation in selecting the network shud help.
Aug 10, 2009 | Samsung Cell Phones
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
System Error E000
My computer is showing system error E000. I can not do anything at all with the computer. Please tell me how to fix it.
Jul 07, 2008 | Office Equipment & Supplies
Canon imageRUNNER 2000 Copier Logo
150 people viewed this question
old marine
old marine
