Question about Fujitsu 24C1 Air Conditioner
The operation and timer lights on my Fujitsu ASU9RMLQ split system AC are flashing on and off several times when the unit is off. If I start it, they still flash and the unit runs poorly. If I hit "test run", nothing happens. If I throw the circuit breaker, it works normally for 5 minutes then reverts back to the flashing lights sequence again, even when I turn the unit off. What gives? I just had the unit serviced and charged a few weeks ago.
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
  • 14 Answers
SOURCE: I installed a Fujitsu ductless split system lines freeze on one
do you have a kink in that suction line?
Posted on Aug 09, 2009
technic_7117
  • 38 Answers
SOURCE: THE RED (OPERATION) LIGHT AND
replace the thermistor
Posted on Aug 16, 2010
SOURCE: The operation and timer lights on my Fujitsu split
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Posted on Nov 23, 2010
How to turn the Timer off on Fujitsu AC Model AR-RAC3E? I have tried several times but failed. The Timer light flashes three times every several minutes. The AC does not work at all. The Operation
remove front cover-pull from bottom and lift up at top reset button is above lights try that first , other checks remote battery, control wires 1-2-3 from condenser to evaporator board.
Jan 20, 2015 | Fujitsu Heating & Cooling
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
Sep 05, 2012 | Fujitsu Halcyon ASU9RMLQ Mini Split Wall...
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
551 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
