Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Xerox XD125F Thank you tryit! I spoke with Britt. He was very helpful at the Parts Drop. I ordered a part. Thanks again for the quick and very helpful reply! RDCC
    President:
  • 2,072 Answers
Your welcome.
Posted on Apr 08, 2008
Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
Oct 24, 2010 | Xerox DocuColor 3535 Copier
After turn it on, the display Shows "H", "4" alternatively, and the XD125f machine does not work. No pre-heating. What is wrong? Thanks a lot for your help! Steven
To reset the H4 condition on your XD125F series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Sep 05, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox DC50 error 9-378 Drum cartridge count expired. How do i reset this error.
You can order a crum chip or replace the cartridge.
Google a business called The Parts Drop.
Call and ask for Britt. I am sure he will have the crum chip to replace and reset that code fairly cheeply.
Aug 09, 2010 | Xerox Office Equipment & Supplies
I need feed rollers for a xerox docuprint n2125 b/w printer thanks phil
google a business called "the parts drop" . They will have what you need.
You can call and talk to Britt. I have done business with them for a long time.
Very good people to deal with.
Dec 22, 2009 | Xerox DocuPrint N2125 Laser Printer
Schematic of the Xerox XC865
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
Fuser lamp on xerox model XC1255 needs replaced
Are you asking directions or where to order.
Anyhow, Either way, google "the parts drop".
Call and ask for Britt, he will have the part at a fair price and
most likely can send you directions.
I don't work there, just have done business with them for years.
First class business.
Aug 11, 2008 | Xerox Office Equipment & Supplies
Xerox Workcenter XD125F
Either the feed rollers are dirty or in need of replacing.
Try this first. Take a piece of regular copy paper and on the front in the middle put a small amount or rubbing alcohol on it. IN the middle about 2 inches wide and 2 inched deep. Dampen the paper, do not drench it, and do NOT use a soapy cleaner since the alcohol will not shred the paper. Place that sheet into the feeder and hold the back of the paper, cause it to jam. What that will do is spin the rollers on the alcohol and paper and clean the roller surface. Keep doing that until the paper comes out clean, then allow a couple of minutes for the rollers to dry before running the machine.
If that still doesn't help the rollers will need replaced. Look up, on Google , The Parts Drop, they should show up first. Call them and ask for Britt. Nope its not me and I don't work there, Just deal with them. Excellent people there.
Good luck and let me know please.
Aug 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Jul 09, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD105f auto doc feed fails. The roller does not descend far enough to contact the page being fed
There is a spring wound clutch that is slipping in the doc feeder.
You can try cleaning it or google a place called The Parts Drop.
Call and ask for Britt he can help you with ordering the right part at a fair price.
Jul 05, 2008 | Xerox Office Equipment & Supplies
Drum symptoms?
Most likely you will start to get streaking. The cleaning blade will finally fail.
Mar 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
