Question about Kenmore HE2 Plus Front Load Washer
Grinds and will not spin - Kenmore HE2 Plus Front Load Washer
  • Kenmore Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinegrinds and will not spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Grinding noise when drum spins
they r hard rubber attachments that keep the tumbler from grinding metal to metal. go to local appliance center 15bucks a set. easy fix
Mar 17, 2013 | Maytag ADE7005AYW Dryer
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Will not spin and making grinding noise
a grinding noise sound i think it come from ballbearing you can chang by qualified person
Apr 17, 2009 | Whirlpool LSN1000LW Top Load Washer
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
