Question about Ruud Central System Air Conditioner
The condenser fan motor has stopped working for the 3rd time. This unit is only 10yrs old.We have already replaced it twice.
    Guru:
  • 587 Answers
Is it the motor or capacitor? If the capacitor is bad the motor won;t run, it will just hum or run real slow.
If it is the motor and it's the 3rd one then you need to go to a more heavy duty motor, for instance if it's a 1/4 horse power then go to a 1/3 hp. etc.
Posted on Jun 01, 2010
  • Bill Long Jun 01, 2010
    Also you might make sure the fan blade is not bent or vibrating when it's running.
Kenmore refr/bottom freezer has quit freezing 3 times in last 3 weeks.
If the fridge is 10yrs old or more the newer models will pay for themselves with efficiency fairly quickly. now on to the "barking" that may be the fan motor(that blows air over the condenser fins) or the compressor the later i point you to my first statement. the fan motor can be lubed with a graphite type powder on the bushings, or replaced from one of the many parts places online eg: sears parts direct, repair clinic etc. RC has videos to help with some repairs too.
Jun 24, 2012 | Refrigerators
My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
Aug 12, 2011 | Refrigerators
Kenmore model 3639550610. Ice maker motor and freezer fan motor wont stop. Need to find wiring diagram.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
Sep 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Have 2 year old Frigidaire FAH105N1T Air Conditioner. Fan stopped working on fan or cool. Serviced twice and they said fan needed to be oiled. Worked 3 weeks then they said it needed fan motor. Bought new...
it possible to replace the defective as follow:
1- take out the unit
2- remove the top cover
3- try to take out the wires from there connections and note each color to witch connection
4- loose bolt of indoor blower to the shaft
5- open the bolt of the condenser fan to the other end of motor shaft and take out the fan
6- open the fixation nuts or bolts of the motor then slide it outside.
7 replace as take care about witch side of shaft is for blower or fan.
Sep 06, 2009 | Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Mar 11, 2009 | Heating & Cooling
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
Ruud Central System Air Conditioner Logo
305 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
