Question about Canon PIXMA MP530 All-In-One InkJet Printer
MX310 code 5100
This thing is not printing copying nothing what does this code mean
  • Anonymous Feb 10, 2009
    I pressed the reset button for 5 secs but it didn't help.
  • Anonymous Apr 15, 2009
    printer is not taking in the paper...put more in and nothing...It just keeps saying load paper
    Problem Solver:
  • 20 Answers
Sir,
you need to reset your printer by pressing the reset button for 5sec
yours,
alecz
Posted on Apr 23, 2008
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Error 5100
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
or you might try
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or a foreign object . check there is nothing even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
hope this helps
Jan 26, 2011 | Canon PIXMA MX310 All-In-One Printer
What does 5100 mean in canon mx310 series printer
There are several possibilities.
Have you changed out a ink cartridge lately? You can try and do a power reset by holding the power button for about 1 second until the machine powers down. You can also remove the power plug. Wait at least 30 seconds before turning the printer back on. Then wait for the printer to fully cycle before trying to print.
There are other possibilities. Let me know what has happened just before you saw this error code and I can give you more information.
Brian
Jan 22, 2011 | Canon PIXMA MX310 All-In-One Printer
Pleace help me about code error 5100
The error code 5100 means that the ink cartridges can not detect by the printer.
Dec 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
There are a error massage check printers 5100
Error 5100 on Canon's usually means there is an obstruction in the printing path stopping the paper feeding properly, or the clear film sensor the cartridges use may be dirty.
Check inside your printer for any foreign objects and also see if the clear film sensor is dirty. Clean with methylated spirits very gently if you have to.
Hope this helps.
Apr 03, 2010 | Canon PIXMA MX310 All-In-One Printer
Error code 5100 check print need to know how to check print
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon MX310 Office All-In-One Printer
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310-cant even figure out how to copy!
Canon PIXMA MX310 Office All-In-One Printer User Manual
here you go here is the manual for your printer hope it helps and thank you for using fixa
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
104 people viewed this question
old marine
old marine
Corne Viljoen
