Question about Intex Easy Set Pool 15x36
Outside ring how firm should the outer ring be when setting up the pool. should i be able to bounce a penny off of it or should there be some give in it.
  • Intex Master
  • 8,404 Answers
Does not require high pressure ... doesn't have to be like a boot camp bunk. Put your change away.
Posted on May 31, 2010
Pump is leaking from the cap
If the water is leaking from the trap lid then the o-ring is not properly set or the lid is cracked.
Try using some silicone based lube on the o-ring and then reset the lid making sure the o-ring is properly resting on the outer lip of the pump pot.
Rod
US Parts Center
Jul 30, 2012 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
The water level in my pool dropped over a foot overnight. I refilled and within hours it dropped again. How do I find the cause/leak and repair it? Thanks
check for any signs of water by hoses/pump....outside of pool on ground and leaks by under the inflatable ring outside...good luck!we had a neighbor or stray cat that would jump onto ring to drink!caught it after seeing "foot prints"....had to wait and catch it...but scared her with hose and patched pool...had teeny points from claws!
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
I noticed my pool was leaking air. I opened the upper ring blow up valve and there is hole inside of it. Can this be repaired? I would hate to get rid of my pool just because the air valve has a hole...
Take a 12 X 12 piece of plastic wrap, wet the pool ring, slide the plastic sheet along until you see the air bubble appear, mark leak with marker pen. Use repair patch. I swear this is better than soapy water!
Jun 19, 2010 | Intex Easy Set Pool 15x36
The top ring on my easy set pool leaks air. How
I suppose the pool is already full of water. You could remove some of the water, then use soapy water and a paint brush to find the leak. Bubble blowing liquid is ideal for this. This will be easier on the the outside than on the inside. Once found, you may be able to fix with duct tape. But they sell repair kits that probably work better. Don't use a tire or bike tube patch - those are for rubber. I hope this helps you, and I hope the kids have fun in the pool this summer! Al K
May 25, 2010 | Intex Easy Set Pool 15x36
I have water leaking from the bottom of the ring lock.Took it apart don't see rubber o-ring.Is a rubber o-ring normally installed around the outside of the impellar housing?If so do you know the part...
You should just have a "O" ring on the difuser about a 2" ring at the center opening and one about the size you describe on the seal plate or in the pump housing. Ether one at the outer edge. You probally have a bad seal. You will need to remove the impeller and replace this before you put the pump back together. Generally if you pull the wires and take the pump to the poll store they will do this for you for the price of parts and can match your "O" ring's to the pump at the same time. This is always your best bet once you open the pump to get all this done at the same time. Good luck.
Mar 06, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Intex Easy Set Pool 15x36 Logo
77 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
