I have a 1999 plymouth voyager that recently overheated while the ac is on. the fan relay sensor has been changed, but when I turned on the ac the fans stop working and the van overheaths. help...please whats wrong?
  • 2 more comments
  • alma_diaz May 31, 2010
    do you think this is an electrical shortage somewhere?
    thank you i will try this, will let you know. thank you.
    what i noticed is that the temperature will get high and the ac is off, the fans will not come on at all. when the fan relay sensor was changed they came on, but as soon as i turned the ac, the fans just stop working.
  • alma_diaz Jun 01, 2010
    is there another name for this part? can't find it under " high side cut out switch"
  • 6,927 Answers
Check the high pressure switch on the ac high side line.
Posted on May 31, 2010
  • 1 more comment
  • Ronny Bennett Sr.
    Ronny Bennett Sr. May 31, 2010
    No,I do not,check the high side cut out switch,it controls when the cooling fans come on with the ac,and it cuts the compressor off if the compressor head pressure gets too high,change this switch before doing anything,it is the most likely problem
  • Ronny Bennett Sr.
    With the ac off ,the cooling fans will come on,and then go off as the engine is cooled down,they will do this on there own,but the ac ,as it is turned on,the pressure switch on the high side line tells the cooling fans to come on,but may only come on when the pressure gets up on the ac high side,about 250 psi,and sometimes the switch is made for it to come on sooner.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jun 01, 2010
    ac High side pressure switch
1999 plymouth voyager overheating cooling fan not working
Someone would need to check the fan relay for voltage and then jumper it to see if the fan will run.
Oct 16, 2012 | 1999 Plymouth Voyager
How do you test the radiator fan relay switch on a 1999 plymouth voyager
You would need the wiring diagram for that circuit to test the relay, one wire is battery power, one is power from the key switch, one is a ground signal from the computer, and the fourth goes to the fan motor.
The engine temp sensor tells the computer when the engine reaches 220 degrees and the fan is needed.
Oct 05, 2012 | 1999 Plymouth Voyager
My 1992 plymouth voyager 3.3l engine is overheating.i have replaced the cooling temp. sensor and fan relay and the fan itself what could be the problem?
could be a bad radiator, thermostat, not enough antifreeze in coolant, or worse a bad head gasket, just to give you an idea where to check next
Apr 12, 2011 | 1992 Plymouth Voyager
Fans won't kick on and van is overheating
Check for a blown fuse, swap fan relay with the ac relay, if none of thease work find a diagnostics scanner like a snapon modis. with the scan tool you will beable to command them on and off, otherwise your temp sensor is not working properly, or the fans them selves my be worn out.
Oct 25, 2010 | 1998 Plymouth Voyager
Radiator fan will not kick on 1999 voyager flex fuel ,i already replaced coolant sensor
Check you replaced the correct fan control sensor switch (not the temperature gauge sender),
Check fan fuse,
Check fan control relay operation,
Check fan will run if power applied directly to it.
Sep 06, 2009 | 1999 Plymouth Voyager
My 1999 plymouth voyager van's radiator fan constantly on
There is a fan relay in the fuse box in the engine compartment. Usually that is the reason why it won't turn off. It fuses in the on position. If you have the manual it will say which one is the fan relay. just pull it out and get a new one. They are not expensive.
Hope this helps
Aug 30, 2009 | 1999 Plymouth Grand Voyager
1997 Grand Voyager overheating
check the fan control sensor in the intake manifold. that is usually the problem. also, if the engine cooling fan does not come on when you turn on the air cond, that is a dead giveaway that the fan sensor is bad.
Jul 20, 2009 | 1997 Plymouth Grand Voyager
Fans want turn on and the 1999 plymouth grand voyager over heats.
the cooling fan module is located under the air cleaner box on the radiator core support. very common problem .it is flat and about 3 inches long held on with 2 5.5mm bolts.
Apr 22, 2009 | 1999 Plymouth Grand Voyager
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
