Installed macally icemouse and it seems to work fine but I keep getting this message: System Extension Cannot Be Used: The system extension "System/Library/Extensions/MacallyMouse.kext" was installed improperly and cannot be used. Please try reinstalling it or contact the product's vendor for an update. I have an iMac G3 running system 10.4.11. Is this message to be ignored,or is there a real problem? After one day, mouse seems to operate fine. Thanks....... David [email protected] 760-634-2218
    Sergeant:
    Champion:
  • 293 Answers
You can ignore it or try to download the updated driver in the internet and install it.
Posted on Apr 08, 2008
SOURCE:
Line access code
To dial an outside (exchange) line you can either dial 9 followed by the number you want to reach or press a pre-programmed key on your handset that saves you from adding the digit 9. The access is normally assigned when your system is installed. Programming of the system can only be done from the first main extension on the system it is normally extension 20 or 21 (the extension that will work if there is a mains power failure), called the default extension. Some systems use different digits either 8 or 7 but the normal is 9. The digit 8 is normally used to pick up a ringing call from another extension. Should you need more help let me know :-) And of course I'd be grateful if you mark my advice accordingly if you have found it useful, thank you.
Sep 29, 2013 | Panasonic KX-T7730 Corded Phone
Norstar M7310 getting Not In Service message
This message means that the system does not see a telephone connected to that extension. Check the extension that you are calling to see if it is operational. Check the extension number by using Feature *0 and pressing the intercom button.
Apr 05, 2013 | NorStar Meridian M7310 Phone
My message light will not turn red so I am not aware that I have a message. If I push the "message" button, it is busy
You are missing a lot of information, but here goes. Your message light is unlikely broken in a new phone. Have someone ring your extension and press "4". Now look at your phone and press MESSAGE. The display tells you who left the message and you get 2 options on your soft keys to call or erase the message.
Now, here's the part you left out. What is leaving the message? It could be coming from CO based voice mail, a TVA system, or a SVM card. If it's a TVA voice mail system, it has to be programmed with your mailbox and extension (usually the same). A message left in the General Delivery Mailbox doesn't light anything unless it's programmed to do something, and a message left in your box usually works if it's properly set up to begin with. We try to set up our TDA's to eliminate GDM messages, so that means that Call Forward lights must be lit at every extension that needs voice mail and there's always a choice to direct callers to extension 101 or some other mailbox but the GDM. If it's CO based, you bought the wrong system, and an SVM card has a set of instructions to assign extensions to slots.
Most likely you'll find the missing information in the Programming Manual of the voice messaging system.
Carl
Jan 11, 2011 | Panasonic KXDT333 Phone
Left mouse button will not work
Have you tried cleaning it with a cue tip?
Normal the buttons get stuck because of dust or dirt gets stuck in them.
Nov 04, 2010 | Macally ICEMouse
We have a KX-TA624 phone system connected to a TVS50 voice processing system. I have one user who has a KX-T7730 phone and his message button wont light when a voice message is left for him. I know the...
The user may have brushed onto the 62x commands to change or turn off message notification. From the subcriber's mailbox, choose option 621 and make sure it's enabled, then 622 and make sure you're using option 2. (continuous). If neither of these work, have the owner log into mailbox 999 and make sure that the owner's extension of the broken extension matches the extension. That's option 611 mailbox number and follow the prompts. The extension is the mailbox.
Carl
Aug 05, 2010 | Panasonic KX-T7730 Corded Phone
I have a user who's light keeps flashing on his Mitel VOIP phone to say he has a voicemail waiting. The user has no voicemail setup on the extension, however I have seen this before. I remember there is a...
I believe that another user has called you and while the phone was ringing, they pressed the message button - and set the lamp.
With the handset still on the cradle, press the message button... read the display. Follow the prompts to cancel or call the message sender.
OR
Pick up the handset, and press the message button. It should call the extension that set the lamp.
The code you refer to is not a standard code. Each vendor or installation is different and the codes can be set how the vendor or site wants them. If the above doesn't work, I suggest you contact the vendor for this info. Or if you have system access, log into the system and find the form Feature Access Codes. Look for the Lamp off code. Dial that code followed by your extension number.
Aug 04, 2010 | Mitel 5220 IP Phone
The New Voice Mail message appears and the light blinks and there are no voice mails.
What system? A Panasonic KEY SYSTEM (76xx/77xx/74xx/72xx phones) can have messages from other sources than the VM system.
If it's a display phone, try pressing the MESSAGE button without picking up the handset and read the display. It will tell you where it came from and you can press INTERCOM and ring that extension.
It works the same way if you call an extension and press the MESSAGE button...that leaves a message. Panasonic systems have a MW cancel code that usually begins with 700. In a TA system it's 700#, in the TDA/TAW's it's *700 plus your extension.
If it's a Panasonic cordless, it's probably hearing stutter dial tone from custom calling features.
Carl
Sep 27, 2009 | Panasonic Lands Phones
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
The message light does not blink when there is a message.
No it is not. that is for dialing home, pager or whatever. the voice mail system needs to have message notification on for your extension and the code it uses. This is done by your tech. If the phone will get a message ligt when moved to an extension that it is known working, on then it is NOT the phone. It is either the phone system or the voice mail system programming.
Let me know,
Thanks.
Bob
Oct 15, 2007 | Toshiba DKT-2010 Corded Phone
Open Questions:
BITDEFENDER TechNical sUPPort pHoNe ~\18OO/8\O/3\1O69/~ numbeR activations Usa BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he BITDEFENDER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 18, 2019 | BitDefender Computers & Internet
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
