Question about Car Audio & Video
I need to find a manual for a road gear amplifier.
I need to find a manual for a road gear 250 watt car amplifier. Do you know where I could download one?
  • 7 Answers
SOURCE: 220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Posted on Apr 03, 2009
  • 56 Answers
SOURCE: What fuse do I use for a 600 watt car amplifier
956
You will need a 6 Gauge wiring kit with a 50amp fuse to the battery. You can verify this by looking at the kits being sold on the internet for 600 Watt car amps.
Posted on Apr 18, 2009
demonsm
  • 253 Answers
SOURCE: What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Posted on Jul 24, 2009
  • 149 Answers
SOURCE: I am wondering about car amplifiers, I don't know
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Posted on Jan 27, 2010
  • 12 Answers
SOURCE: Can a radio shack 250
Yes. It won't be great, but if you're starting out you should be ok. Musiciansfriend.com has some of the more popular pa options - generally radioshack=bad.
Posted on Mar 05, 2011
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
How to reset the thermal circuit on a road gear
Normally it resets itself when temperature drops, why , what is the problem
Sep 09, 2014 | Car Audio & Video
How do i know if my palomar 250 is a high drive or low drive amp
If it is made by Palomar and it is a small amplifier, you can bet it is a low drive. Check those transistors. It could have the new Mosfet 655's in which case definitely low drive 3-6 watts input max.
Mar 30, 2014 | Palomar 250 SSB/AM Linear Amplifier for...
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
How many watts is it?
KA3 offers 125 watts RMS at 4 ohms, 200 watts RMS at 2 ohms, and 250 watts at 1 ohm. The high-current section offers 50 and 75 watts RMS at 4 and 2 ohms, respectively
Sep 30, 2009 | Jensen KA3 Car Audio Amplifier
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
474 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
