Question about RTO Atwood Water Heater - 6 Gal LP
When I hooked the water line to the camper for the first time this year, water came pouring out from under the water heater. Any ideas what happened?
    Novelist:
  • 145 Answers
With any water heater that's a sign that the water heater is shot because the glass shelled interior tank broke. It usually happens around the year on the water heater, say its a 7 year water heater, it would break after the 7 year point. There are other factors such as water pipes leaking, but they are on top or the side and would not be leaking from underneath.
Posted on Jun 01, 2010
My camper water heater with electronic ignition lights for a short few second burst 3 times and then times out due to heater switch inside camper..why
Sounds like it may be a dirty flame sensor. It can be gently cleaned with steel wool or scotch bright pad (not emery or sand paper). Its a small rod that sits in the flame. I believe it is part of the spark ignition assembly on your model. Only open your burner compartment though if your are certain you have the skills (and perhaps gaskets etc) to reassemble it safely.
God bless
Aug 06, 2014 | RTO Atwood Water Heater - 6 Gal LP
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
With in 3 1/2 years two time main board went bad, inlet valve went bad, whether I keep that machine or I exchange that machine. machine problem or product problem ?
I believe that you have problem with fluctuatin of voltage in Line. Will be a Good idea to install a Stabilizer Voltage in line for to control of Heater , and to keep safe the control board.All the machine will be expose to this fluctuation.
God bless you
Oct 15, 2013 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
FOR A CAMPER
If you need instructions on current set-up you have please describe it as best you can. If your looking for an easy set-up and can get to lines fairly easy, just buy a 1/2" pipe nipple and remove water line fittings from tank and join them together . That's a by-pass.
Feb 10, 2013 | RTO Atwood Water Heater - 6 Gal LP
We have a 2011 Keystone Sprinter 311 BHS camper that we bought last year; it has a 6 gallon gas and electric DSI auto ignition water heater, It won't stay on. When we first turn it on, you can hear...
Are you getting any hot water from taps? If not, check by-pass valve on back for proper positioning. You want cold going in bottom fitting open, as well as hot coming from top fitting open too. Any valves etc., in between should be closed. Let me know what happens please.
May 16, 2011 | Water Heaters
Too hot wather/ thermostat problem
its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
May 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a keystone camper and apparently the hot water line under the belly is frozen because I get no water flow to the sink...funny thing is at the shower and bathroom sink the faucets are switched the...
YEP. I'M IN THE RV BIZ AND IT'S MORE COMMON THAN U THINK. SOME DEALERS DON'T DO A THOROUGH JOB OF DELIVERY INSPECTIONS. ANYWAY, TAKE A HAIR DRYER AND THAW OUT UR FROZEN WATER LINE. SWITCH AROUND THE OFFENDING WATER LINES, THERE SHOULD BE ENOUGH PIPE TO ACCOMPLISH THIS. ASSUMING THE LOW FLOW IS WHEN UR USING UR PUMP, YOU CAN TURN THE PHILLIPS SCREW ON THE HEAD OF THE PUMP CLOCKWISE TO GIVE IT A LONGER STROKE. CHECK THE SCREEN FILTER FOR ANY DEBRIS, KINKS IN THE LINE BETWEEN THE PUMP AND WATER TANK, MAKE SURE THE AERATOR SCREENS AT THE SINKS AREN'T PLUGGED.
Dec 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
106 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
