Question about Singer 7422
Threading The thread from the needle will not catch the thread from the bobbin. Just clicks. Thank you!! Lisa
  • 40 Answers
Could be the timing. check your needle first. Use a new needle and see if that helps. Make sure it is installed with flat side in proper place. Make sure it is correct length.
Posted on Jun 01, 2010
Shuttle action not working, doesnt catch the down thread, bunches up thread and breaks needle.
Hi. I did not have this exact problem with my Featherweight. My machine was not stitching properly (top stitch looked so-so, but lots of thread bunching on underneath side of fabric). I took it to repair shop and learned that I was threading the needle thread on the wrong side of the metal plate which is part of the take-up arm (I do not think that the threading instructions make this distinction). After the repairman pointed out the problem & threaded the machine, it made a proper stitch.
My suggestion for this issue: check the bobbin threading. My bobbin has to be inserted so that it turns counterclockwise in order to catch the down thread.
May 27, 2014 | Singer Featherweight II 117
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
My bobbin thread won't pull up. I tried what was listed to do, but it didn't work. Please help me~!!
Here are some things to check:
1. check the threading and tension of the top thread. It may look like it's threaded correctly but not be. When you pull on the thread is there some tension but still pulls out? Make sure it isn't catching somewhere on the path. Also make sure it's not too loose. If it's too loose it won't be able to pull the bobbin thread up enough.
2. check the bobbin threading and tension. Does it have some give but not reel out a ton? Is it catching? Is the bobbin in all the way - hear a click when inserting it?
3. Do you have the right needle for the machine? Is it inserted correctly? Try sewing through ordinary cotton first. Is it stitching? If so then you may not have the correct needle size for what you are trying to sew through.
Mar 31, 2011 | Brother XL-2600
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
May 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Pfaff Expression 3.0 works great in the shop, but when I get it home the bobbin thread doesn't engage with the needle thread. The needle thread ends up making large irregular loops on the bottom of the...
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
Apr 12, 2009 | White Sewing 1521
Singer 7422 Logo
142 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
