Question about Frigidaire FAC084N7A Air Conditioner
It freezes i have to put it on fan to defrost it
  • 6,826 Answers
It needs cleaning ,if it is a window unit,remove it from the window,from it`s shell,and take it out side and wash it out,be careful not to bend over the fins on the evaporator,and the condenser with the water hose.If this does not help,then it needs some freon.
Posted on May 31, 2010
Upper fridge won't go below 50 degrees,but freeze section is freezing things to hard...do not hear the fan running.....ice behind panel in fridge....
Auto defrost mechanism is not working . Check defrost heater element, defrost timer, defrost thermostat for operation.
In meantime defrost unit completely and it will work fine for a few days till it freezes up again. Probable open heater element.
Nov 20, 2015 | Refrigerators
The Evaporator freezes and fan down by evaporator does not work
Replace the fan that is not working and then see what happens. If evaporator still freezes up after the replacement then the defrost circuits need attention - i.e. the defrost timer, defrost heater element, defrost thermostat.
Aug 19, 2015 | Refrigerators
The fridge is freezing. This happend after a hot summer and the internal fan was on almost a month. It started to freeze before the fan was put off. Thermostat is my suspect, but I can't understand that it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Miele K8952SDED Refrigerator
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Refrigerator is not getting cold
fan motor running in freezer?- put unit in defrost the timer has a slotted set screw turn clockwise the unit will go into defrost the electric heater will start/ the fan in freezer and compressor will stop do a few times to get rid of ice if does not go into defrost a couple of things maybe wrong the first thing to check is fan motor in freezer should be running if not everthing will freeze
Jan 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side works for a week, then freezer coils freeze up
defrost system problem tell me more,is the fan in the freezer working,can you find the defrost timer and put it in defrost?this way you can remove the freezer back panel and see if the defrost heater comes on,let me know what you find-mike
Oct 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge freezing up on back wall of fridge not defrosting
is freezer fan working?remove freezer back wall put frig. in defrost,watch freezer to see if the heater is melting the ice,if not wait 20 minutes till freezer out out of defrost and fan comes on,if it does you have a bad heater and bimetal switch (the little silver round thing clipped on coils,let me know-mike
Sep 22, 2008 | Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FAC084N7A Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
