Question about Kenwood VR-414 5.1 Channels Receiver
My kenwood vr-414 receiver shuts on then off standby is blinking
    President:
  • Kenwood Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Videomy kenwood vr-414 receiver shuts on then off - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
I have had a Kenwood VR-407 reciever for almost 9 years now but it has just started cutting off. The small power/standby light above the power button goes off when I power it up but then it shortly...
If you've already disconnected the speakers then I suspect the fault is internal on the amplifier and the unit is shutting down to protect iteself.
The fault with most amplfiers can normally be traced to blown or leading capacitors (bulge on the top or liquid around base) which can be replaced for little cost if you've got the technical ability and equipment to desolder and resolder components on a PCB.
First thing to do would be to remove the cover and check the capacitors as detailed above.
Jul 23, 2011 | Kenwood VR-407 Receiver
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
Oct 03, 2009 | Kenwood VR-509 Receiver
Audio Receiver shutting off
check your speaker connections you have a short or wires touching eachother
Mar 14, 2009 | Kenwood VR-406 Receiver
My Kenwood VR-209
your speakers wires are touching together. this system has a protecter so you don't blow out the amp. the blinking is how it lets you know that
Jan 28, 2008 | Kenwood VR-209 Receiver
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Kenwood VR 208
It works sometimes, mostly the volume bottem
Nov 26, 2007 | Kenwood VR-506 Receiver
Kenwood VR-307 Receiver standby light blinking
Hello, sorry to say this, but there is a hardware error. Possibbly something is wrong at the output stage. Please send it to tech for a repair. But first disconnect the speakers and then try to turn it on. If there is no change the error is still present. Best regards. Arpi
Jul 17, 2007 | Kenwood VR-307 Receiver
Clip indicator
try this like it should tell you what you are looking for. http://en.wikipedia.org/wiki/Clipping_%28audio%29
Sep 29, 2006 | Kenwood VR-9070S 7.1 Channels Receiver
Kenwood VR-414 5.1 Channels Receiver Logo
420 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
