Question about Acer Aspire 1710 Notebook
Corrupt bios Can the bios be replaced and or can I flash it from a floppy usb drive. Would appreciate any other suggestions. Thanks Wayne
  • 77 Answers
The only way to flash your bios right now is externally flashing it. this is quite a complicated procedure and requires a bios programmer.
you need to find a service center specializing in this fix.
try this link http://www.aqstech.com/
Posted on Apr 09, 2008
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
Corrupt & Locked Bios
When you flash the bios (normally from a floppy drive) it should overwrite anything that is there.
In this case you must boot from the floppy. Unfortunately, with a laptop you don't have that option.
I suggest you put the bios flashing utility that you probably downloaded with your bios update file on a flash drive. I think your laptop has the ability to boot from that.
Anyway, on startup, press F12 until you get the boot options and try that.
I take it that you know the support site URL, but just in case, it's support.dell.com
Nov 12, 2009 | Dell Inspiron 2200 Notebook
Emachines notebook m5310 corrupted bios recovery
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Reboot the system
Turn the system off
Oct 14, 2009 | Computers & Internet
Dead gigbyte GA-81945 Pro ,, Help with compatabilty issues!
Hi bob_snz:
If the bios is corrupted, as it seems to what happened, you may be able to fix it.
So, what you can do to restore this board, if the bios is replaceable is to buy a new bios module for this board. Be sure to get the exact model marked on the board with the version #.
u
The data is still on the hard drive. So, what you can do with the hard drive, if you decide to get a new board instead of trying to fix this one is to put the hard drive in another computer and set the drive as slave. Next is to copy your data to a DVD (s) or another hard drive.
In this case you have a couple possibilities. Try to fix this board with a new bios module (if it is removable).
Unplug your hard drive. Use another computer to download the correct bios flash version. Use a floppy if available, to try to flash the bios again. The floppy would be self boot to access the bios without booting the computer. Usually the floppy only boots what is necessary to get to the bios firmware and loads to the bios flashing it to the correct firmware.
Since the bios may be corrupted, this operation may not work, but may be worth a try. If you do not have a floppy on the computer find a floppy from a friend or if you have one, install it and proceed.
Again, it may not work if the bios is completely out of commission.
Hope it works.
Aug 23, 2009 | Intel Motherboard
Acer travelmate 4650, after bios flashing, no display.thanks.
HI there
Sounds like the bios flash has failed, the only thing you can do now is try to flash again, make sure you have the right bios update for that model machine, suggest you get a USB floppy drive so you are able to re-flash the bios, if it still doesn't work then the machine is rendered useless.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer TravelMate 341T Notebook
Won't boot
Under normal circumstances you do not need to boot into a drive to flash your BIOS. Normally you would take a dos boot floppy and the latest BIOS firmware and put them on a floppy, which is then inserted into the floppy drive before turning the computer on, and if the bios boot priority is set to boot from floppy before the harddrive, it will ask to boot from the floppy, which allows you to flash the bios from a command line or text graphical interface.
*Note that you may be able to use a cd, but floppy is the oldschool way - if you could boot into an operating system you could use the modern methods which flash the bios while running an OS.
Your board comes with Q-Flash in the BIOS, which means you are able to log into the bios and flash it using this utility and by putting the BIOS firmware on a floppy and inserting it into the computer.
Please see Here for instructions and Here for the latest firmware.
If you cannot access the BIOS, meaning the BIOS is completely bricked, then you will need to buy a new motherboard. Unfortunately there is no way to fix a BIOS which is completely bricked.
Dec 16, 2008 | Gigabyte GA-K8VT800 Motherboard
Regarding the hdd size and bios update
The issue with your board is that it can't see drives above a certain size. This does require a BIOS update, usually involving a floppy drive. Look in your BIOS - there may be an option for you to be able to boot from other devices. Check to see if "USB Floppy" is one, as it means you could potentially use an external floppy drive, which are cheap at most electronics stores.
Alternatively, if you or a friend has another computer, you might try borrowing a floppy drive to do the update.
Alternatively, you could go to the manufacturer's website and check the information they have for your particular board. Many now let you download an executable file with the recent BIOS updates that you can use without having to use a floppy drive. Some also have methods that you can burn to a CD.
Mar 14, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
N600C Bios Update
You can make a bootable cd of the flash image and update the bios that way.
Jan 20, 2008 | Compaq Evo N600c Notebook
Acer Aspire 1710 Notebook Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
